455 "c" head,now a "boat anchor"?
Old Sep 26, 2024 | 11:25 PM
savage'74's Avatar
Brought a pair of "c" heads 2 hours away from home for $10,so didn't lose a lot. But the heads were stored in boxes with spray foam and one head had a lot of moisture causing pitting at base. Not sure if it can be saved, otherwise it's a cleaned head and was told they were checked out sometime before I received them? Any opinion or help would be very appreciated 👍
Old Sep 27, 2024 | 04:21 AM
BillK's Avatar
They look like they have been sitting on the ground in a junk yard for 20 years Might as well take them to the scrap metal place. I bet it would take .070 or more to clean the pitting up where the head gasket seals around the cylinder.
Old Sep 27, 2024 | 04:25 AM
You could always take them to your machinist and see what he says. How much can you take off of the heads or block before it causes problems?
Old Sep 27, 2024 | 04:28 AM
BillK's Avatar
Much more than .020" and you start having intake manifold fit problems. Believe me, that head is junk.
Old Sep 27, 2024 | 04:57 AM
CustomBruiser's Avatar
As with most things, the answer is "it depends." I ran K heads with .045 and .090 taken off. Like mentioned above, you'll have to take the same amount off the intake side of the head so that the manifold will still fit. And you'd have to choose pistons and head gaskets etc. based on how much compression you want to run and balance that with the cost to machine them.
Old Sep 27, 2024 | 08:13 AM
Keep in mind that the intake fitment depends not only on the amount cut from the head but also the compressed thickness of the head gasket. The OEM steel shim gaskets were 0.017" or so. FelPro blue gaskets run about 0.047" compressed. Cometic C5808-060 head gaskets are 0.060" compressed. Cometic C5808-080 are 0.080" compressed.
Allencarney
Oct 16, 2024 01:09 AM
Rallye469
Aug 27, 2024 04:16 AM
rudeke
Aug 7, 2023 04:46 PM
Aug 5, 2021 11:26 AM
Fazer
Feb 6, 2020 06:26 AM
