455 A body build ideas.
Old Oct 26, 2011 | 08:03 PM
joepenoso's Avatar
Question 455 A body build ideas.
I have a 1971 442 stock convertible with factory cast iron headers, H heads, stock cam, carb and pistons , 400 transmission, HEI ignition, 255/70/15 rear tires (29 inch tall) with a 3.08 rear end.Outside Air Intake.
I like to run on 87 octane low lead and want a strong power band from 1,000-5,000 rpm. It revs out sometimes but basically the car is set up like a power glide with an overdrive third gear.
- Do I need to do any oiling mods such as Toro/ Milodon oil pans ,restrictors?
-Cast or forged pistons?
-Compression ratio?
-Keep the stock cam or ....?
-Apparently the heads are worth something and would like to keep them or maybe sell them and get aluminium heads?
-What's the tightest quench I can use or don't bother?
-Keep the stock cast iron 4bbl manifold or....?
Thanks in Advance
joepenoso
Old Oct 26, 2011 | 09:23 PM
ah64pilot's Avatar
What is your budget?
Old Oct 27, 2011 | 05:21 AM
507OLDS's Avatar
Did a guy named Don own that 71 442 convertible?I think his name was Don.
I would do some sort of resto/sleeper engine.Make it as stock appearing as possible.
The block,crank,and rods can be reused.The Keith Black pistons would be fine for what you are doing.I would aim for 9:5:1 compression.You don't need any special oiling gadgets.A stock pan with a Melling pump,and matching pickup will be all you need.Get a modern cam grind.You could do the factory intake,with a Q-jet,or you can go aftermarket,depending on what your goals are with the car.It sounds like you just want a good cruiser,with more power than stock,which is not hard to do.As far as the heads go,you could keep them,and do a 71 W30-appearing engine,and get a repop W30 aluminum intake,or sell them and go another route.You could also do a set of correct 71 G-heads,with the iron intake.If you go with aluminum heads,then definitely get an aftermarket intake,like a Performer,Torker,or Performer RPM air-gap.You have a 3:08 gear,and a taller tire,that will lessen your ratio,so run a 11" converter with no more than 2,000 stall.
Old Oct 27, 2011 | 07:39 AM
joepenoso's Avatar
Thumbs up
I only know the previous owner, haven't checked out the history yet
Sounds good
"F" block
Forged cast or hyper ?
Will it run on 87 regular still?
Got it
Any suggestions?
I thought the "H" heads were correct for 1971?
Thanks for your advise
joepenoso
Old Oct 27, 2011 | 07:49 AM
507OLDS's Avatar
You could use a hyper or forged piston.
The cam can be chosen,once some of the other variables are in place,like compresion.You can run iron heads with 9:5:1 compression on 87 with the right grind.
The H-heads were used on all of the 71 W30 engines.The G-heads were used on the regular 71 442's,and all other 71 455's.
Old Dec 9, 2011 | 02:37 PM
joepenoso's Avatar
If two heads were offered in 1971 .....one was "H" on W30's and the other was "G" for the plain Jane 442's what was the differences?
The flow between them wasn't noticeabley different.
thanks
joepenoso
Old Dec 9, 2011 | 05:31 PM
cutlassefi's Avatar
Running 9.5:1 on 87 will be a challenge, especially with a 3.08 gear and tall tire. I'd go no more than 9.0:1 with good squish, .045 or so. Smooth out the combustion chambers and a mild cam and you should be fine, maybe a single pattern or something with very little duration stagger but enough off the seat time, not a fast ramp.
Jmo.
Old Dec 9, 2011 | 07:22 PM
507OLDS's Avatar
No,you won't make more power with one or the other,but they made a lot less H's.You could have a sweet set of Edelbrocks,with all the bells & whistles,if you sold the H's.
mhouston44
Feb 20, 2015 09:18 PM
a70oldscutlass
Dec 21, 2013 08:29 PM
1964F85
Feb 12, 2010 07:14 PM
ronman442
May 18, 2009 01:21 PM
69 442 protour
Dec 9, 2006 09:25 PM
