455 block info for trans
Old April 15th, 2013, 06:01 PM
foo
foo's Avatar
What am I looking for to tell if the block can support a manual trans? Pictures are very welcome.
foo is offline
Old April 15th, 2013, 06:58 PM
edzolz's Avatar
Yes a 455 Olds will support a manual transmission. What is unknown about your block is, does it have the drilled hole for the "Z" bar pivot, and is your crank drilled for a pilot bearing? Any manual trans BOP bell housing will bolt up to any Olds modern V8.
edzolz is offline
Old April 15th, 2013, 07:15 PM
foo
foo's Avatar
ok so where would the hole for the z bar be, on top or the side(driver or pass.)? also is it just the crank that is to be drilled, my block was hooked to auto originally the block cast# 396021F on front, I believe its the original engine out of my 70 442.
foo is offline
Old April 15th, 2013, 09:24 PM
2blu442's Avatar
The drivers side rear. Here's some pictures I had on the computer of the Z bar installed.
Then here's a block on a stand. Look for the bolt hole near the back of the block, just under the head and toward the transmission. The bolt hole with a round pad milled into the block around it. Just forward of the alignment pin for the transmission or bellhousing.
John
2blu442 is offline
Old April 16th, 2013, 04:43 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
any f block has a z bar hole, from my experience. only fA blocks may not.
J-(Chicago) is offline
Old April 16th, 2013, 09:10 AM
Of course, the lack of a threaded hole for the Z-bar pivot ball just means that either you need to use a hydraulic throwout bearing or a bolt-on bracket to mount the ball. And the pilot bearing issue is obviously in the crank, not the block.
joe_padavano is offline
Old April 16th, 2013, 12:50 PM
foo
foo's Avatar
very good, thank you for the replies and pics for reference
foo is offline
Old April 16th, 2013, 10:06 PM
64Rocket's Avatar
I hand drill the crank about 1/2" in and make it a bit larger than the input shaft of the trans. Then get the adapter pilot brg. Have never had any problems.
Gene
64Rocket is offline
Old May 24th, 2013, 06:19 PM
rpclearwater's Avatar
Clutch Pics
This might be a old post but thanks for the detailed pics!!!! Will make things real easy. Cant see where the clutch pedal return spring goes though? Any help? Thanks!!!
rpclearwater is offline
TimKillinger
May 31st, 2012 09:32 AM
sx455raidercelticfan
August 1st, 2010 08:03 PM
viper771
May 31st, 2010 12:40 PM
Quick Reply: 455 block info for trans
