455 BBO Mods needed for auto transmission.
Old Aug 9, 2011 | 03:54 PM
Al2011's Avatar
I'm looking at a big block 1972 455 BBO that's in a Ford truck with a manual transmission. What mods are needed to put this motor in my car with auto transmission. I have a 72 cutlass S ,stock 72 3 speed trans. Also why are the HP & Torque ratings different from 70 to 72. Is there really a noticable difference when driving or is it that way they had to rate motors because of the laws back then? It's confusing..Any help will be appreciated.
Old Aug 10, 2011 | 09:19 AM
Unbolt the bellhousing, remove the flywheel, bolt on a flexplate, bolt on the AT.
There were two issues with the HP drop. The biggest effect was the change from a gross HP rating to a net HP rating. Gross was the bare engine with an optimized air inlet and exhaust. Net was as installed in the car with real air cleaner, exhaust, and accessories. There is an SAE spec for this test configuration. The other issue was the federal requirement to use low-lead fuel starting with the 1971 model year, which lead to lowered compression and milder cam profiles. In 1971 GM published both numbers (gross and net). As an example, the gross number for the W-30 dropped from 370 to 350 HP. The net was like 320 HP, so you can see that the largest part of the drop was simply the test method, not the emissions changes.
Old Aug 10, 2011 | 09:26 AM
Al2011's Avatar
72 455
Thanks for the explaining this to me. So you think a 72 olds 455 with Ga heads is a powerfull motor or comparable to the 1970, or is it a big difference?
62CUTLASSINKEYWEST
Aug 21, 2009 03:50 PM
kevin442
Site Help
Feb 22, 2009 05:48 PM
m_tanner_75
Dec 28, 2008 02:06 PM
olds69er
Apr 14, 2008 06:45 PM
<George>
Drivetrain/Differentials
Jul 12, 2004 11:00 AM
