455 assembly questions
Old Apr 26, 2024 | 05:20 PM
PaulWinn's Avatar
Just checking with experts here as I go - continuing with the embarrassing questions. I am a SBC guy doing my first BBO
Reusing the old roller timing set. Crank sprocket has bevel on 1 side, square cut other side, markings on both sides, unknown brand.
1. Does bevel side go IN?
2. Of the 3 keyway options (square cut, pointed cut, rounded cut) which one is "straight up", no advance or retard?
Reusing good rods with ARP bolts that have already been ran a few thousand miles.
3. No need to torque, retorque, retorque, right?
4. Does it still need the ARP special lube, or red locktite?
5. What ft lbs torque if I dont have stretch gauge?
And oil pump install
6. Bolt on dry right? No gasket or sealer
7. Hex shaft goes in with pump from the bottom, not drop down from the top?
Old Apr 26, 2024 | 05:54 PM
I don’t know the answers to your questions, but I can say get a degree wheel and verify the cam is installed correctly.
On one of my cam swaps, I put it in dot-to-dot and the engine had no low end power. Many years later I got a different cam and a degree wheel, checked the old cam before pulling it, and found it was 8 degrees retarded. That convinced me to always degree the cam.
Old Apr 26, 2024 | 06:38 PM
BillK's Avatar
The bevel should go in. Most of the time the "rounded" keyway is straight up. Post a picture of the gear.
No need for the three times.
Yes you need the ARP lube. NO LOCTITE !
The correct torque should be on ARP's web site. You have to look up the kit part number first, then the instructions.
Correct on both
Old Apr 26, 2024 | 06:50 PM
v8al's Avatar
Registered Olds Owner
There's supposed to be a small washer/retainer on the oil pump shaft that keeps the shaft from falling out and being pulled from the motor when you remove the distributor. If this retainer is installed then the shaft can't be "dropped in from the top".
Old Apr 27, 2024 | 08:22 AM
That sheet metal retainer is only there to prevent the shaft from falling through to the floor when you install it with the motor upside down on the engine stand and no distributor in place yet. Once the oil pump and distributor are in place, the shaft can't go anywhere. More to the point, when the shaft gets stuck in the distributor drive gear (which is ALWAYS does), all the retainer does is make it more difficult to pull the distributor and shaft out while the retainer gets slid down the shaft and into the oil pan. I would suggest not using it and just drop the shaft in from the top once the oil pump is in place.
Old Apr 28, 2024 | 02:50 AM
rickw30's Avatar
^ DON'T USE that medal retainer thingy !
Old Apr 28, 2024 | 06:56 AM
Run to Rund's Avatar
I avoid the stuck pump hex drive problem Joe mentioned by putting a film of moly cam lube on the hex where it goes into the distributor gear.
Old Apr 28, 2024 | 07:02 AM
I've done that with no joy, Joe. Still sticks. Of course it depends on how long you leave it in the engine, I guess.
OldOldsLover
Mar 21, 2022 08:04 AM
Macadoo
Dec 19, 2017 04:16 PM
gbledsoe3
Jun 27, 2017 05:01 AM
GOSFAST
Dec 9, 2013 09:32 AM
anthonylenhardt
Mar 29, 2007 07:54 AM
