455 air conditioning install
Old Aug 8, 2025 | 05:13 AM
79cut's Avatar
Hi fellows
thinking of putting in air conditioning on my 79 cutlass slowly
the alternator is mounted on the passenger side.
dis the air conditioning compressor get mounted on the drivers side on these ?
I see a lot of pictures with the compressor mounted on the passenger side
anyways. Anyone have any tips for what brackets I need to start the little project
Old Aug 8, 2025 | 09:54 AM
The factory only mounted the A/C compressor on the passenger side. The alternator was moved to the driver's side on A/C cars. Obviously brackets, pulleys, and belts are different. Some aftermarket A/C kits leave the alternator on the passenger side and put the compressor on the driver's side. This results in very long A/C hoses running across the engine compartment.
Old Aug 8, 2025 | 01:04 PM
Is this a non A/C car? Or are you doing an aftermarket a/c system? Using a R4 compressor on a 455 requires minor fabrication.
Move the alternator to the drivers side, use the correct A/C compressor brackets.
A/C compressor and alternator brackets are easy to find.
Old Aug 9, 2025 | 10:45 AM
79cut's Avatar
im not sure if it was a ac car
the car had a resto mod so everything was removed including duct work inside
Old Aug 9, 2025 | 01:12 PM
If the firewall has been smoothed, and all the interior parts are missing, then a aftermarket system would be far easier. Unless you had a parts car available I’m guessing getting all the little parts and pieces would be extremely frustrating.
Old Aug 9, 2025 | 02:00 PM
79cut's Avatar
well I don’t really know what or how these were set up inside as far as duct work but I do already have the box and controller
I’m hoping if I can get the air conditioning in and it blows out the main duct should cool down the car somewhat
Old Aug 9, 2025 | 02:02 PM
79cut's Avatar
66wagon
Jun 27, 2025 02:05 AM
Big red72
Apr 13, 2013 01:42 PM
lil_no
Jan 14, 2010 01:19 PM
Southern_Hospitality
Jun 25, 2009 10:46 PM
1FSTLS1
Dec 28, 2007 07:45 PM
