455 adjustable rocker recommendations
Old Jun 9, 2021 | 12:20 PM
John Gregory White's Avatar
Cutlass Salon 455
My fellow Olds friends,
I am looking for some of your recommendation for adjustable rockers for my 68 455
My requirements are:
1) They need to fit under the stock valve covers. (Tight fit in my GBody)
2) They need to fit on C heads with original studs size 5/16. (I may have to bore and tap out to 7/16)
3) only for street application 390hp.
4) and be reliable.
Hopefully someone with experience in adjustable rockers can chime in and I thank you for your recommendations
cheers,
John
Last edited by John Gregory White; Jun 10, 2021 at 08:00 AM. Reason: more details added
Old Jun 10, 2021 | 06:56 AM
442Harv's Avatar
I have a cheap set I bought from Dave Smith, not sure they are still in business anymore? Not a real quality set, but I have had it for about 20 years no problem, but I don't drive the car much also. It is kind of a cross between factor Olds and aftermarket.I have a Engle 22-25-10 cam, and they told me that is about the max their set would work on. Bought a set of Comp from a guy on this site, about a month ago, have not installed, but he said he took the off a stock motor.
Old Jun 10, 2021 | 07:10 AM
I know the Comp rockers with the studs that screw into the 5/16" threads in a stock head will fit under stock valve covers. I actually used the Crane studs and guide plates for the SBF, as they have slightly less height than the Comp parts. I also like the plastic inserts in the guide plates, as this avoids the need for hardened pushrods. These rockers need pushrods that are longer than stock in all cases. Check geometry carefully.
Old Jun 10, 2021 | 07:40 AM
I have the Harland Sharp rockers under the stock valve covers. I used a 3/8 spacer I bought off eBay for a little extra clearance. No leaks, plenty of room, no accessory mounting bracket clearance issues, looks stock. Going on probably 10 years of use.
Old Jun 10, 2021 | 08:06 AM
jensenracing77's Avatar
I used the Harland Sharp shaft mounted rockers and took the baffles out of the stock valve covers and fit fine with stock gaskets.
Old Jun 10, 2021 | 08:22 AM
My442's Avatar
Make sure that you discard the crimp nuts in the Comp 1442 kit, and use the short ARP locking nuts.
I have had this set up in my 442 for over 10 years with no issues.
Fits fine under stock valve covers.
Old Jun 10, 2021 | 09:14 AM
442Harv's Avatar
My 442, why are you saying not to use the nuts that come with the kit?
Old Jun 10, 2021 | 10:27 AM
My442's Avatar
I am not a fan of those types of nuts, as they are distorted to grip the stud threads.
They may work for a one time install, but if you remove them more than once, they could work loose.
The set screw version of the locking nuts works better and is more reliable.
IMHO
Old Jun 11, 2021 | 11:33 AM
dc2x4drvr's Avatar
I’ve had ^^^ on my 455 for years, no issues.
1968Cutlass_S
Oct 24, 2017 04:54 PM
kfzr2
Aug 23, 2015 07:18 PM
joepenoso
Jun 14, 2013 05:33 PM
CutlassLegend
Sep 21, 2011 02:56 PM
2oldsguy
Nov 12, 2010 02:44 PM
