Roller Tip rocker arms vs stock stamped steel
Old Sep 6, 2017 | 01:28 PM
1968Cutlass_S's Avatar
Hello folks, after a long break from working my Olds I am back at it. I have a 1968 Oldsmobile Cutlass S with a 455 out of a 1968 Toronado. I just installed a 260H comp cam and I was considering using the stock rocker arms, replace the stock rocker arms, or get roller tip rockers. Has any one had any luck with the Roller tip rockers? Are they worth the change? Also is there a significant difference going from the stock 1.5 ratio to the after market 1.6? I am not heavily into speed anymore but if there is a significant difference between one or the another I wouldn't mind a few more horses out of the motor. Thanks folks for any help and advice.
Old Sep 6, 2017 | 02:34 PM
RROLDSX's Avatar
As far as I know stock Olds is 1.6 ratio. I've used Ford roller Rockers (PRW).
Old Sep 6, 2017 | 03:37 PM
VC455's Avatar
Barely Registered
The 1.6 ratio roller-tip rocker reduces sliding friction, which cuts oil temperature slightly.
That type of rocker also cuts the side load on the valve stem, which reduces valve guide wear.
Neither of these is of critical importance for a low-mile, non-performance engine.
Whichever you choose will give satisfactory results in your situation.
Old Sep 7, 2017 | 04:54 AM
Tiha's Avatar
I have changed to roller tips ( and destr.pushrods from D.Miller ) on a low compr G headet 455 with a 260H- intake and headers ....and i can say you : you feel it .
10+ hp and low friction
Don´t forget the short poly locks if you stock covers-CCA-4601-16
Old Sep 7, 2017 | 08:02 AM
Cool, thank you all for your responses. I'll probably stay with the stock type rockers since the total with everything I am going to need is going higher that expected.
Old Sep 8, 2017 | 06:36 AM
Run to Rund's Avatar
I have always gotten good performance from stock rockers even with high performance cams.
Old Oct 24, 2017 | 09:33 AM
Originally Posted by DZAUTO
I SWEAR TO GOD I DO NOT UNDERSTAND WHY OLDS DID NOT BUILD THESE ENGINE WITH ADJUSTABLE ROCKERS TO BEGIN WITH!!!!!!!!!!!!!!!
Then you have no clue about production tolerances or reliability.
The factory can very precisely control the dimensions and tolerances of the engine and valvetrain on the assembly line. This eliminates the need for adjustability. By designing the valvetrain to be fixed at one "adjustment" dimension, there is no concern about the adjusters backing off or some ham-fisted "mechanic" adjusting them incorrectly. The car runs fine and warranty recalls or customer complaints are significantly reduced. Solid lifters were never a factory option, so there was no need for adjustability.
Old Oct 24, 2017 | 02:03 PM
Oh yes, I do have a clue. And all of that goes out the window 10-20-30-40yrs later when it's time to do a total rebuild,
And you really think that automakers care about this when they are designing parts to maximize profits on the sale of new cars?
News flash: since solid lifters have pretty much vanished from new cars, no one uses adjustable valvetrains anymore. Chevy LS motors don't have adjustability. The last pushrod SBFs weren't adjustable. Gen III Hemi rockers aren't adjustable.
Should I go on?
Old Oct 24, 2017 | 03:43 PM
Hi Tom, welcome back to the site it was good meet you at the Corvette show. There are plus's and negatives about both types of rockers assy's. The ease of maint of the stock type and then the flexibility of the adjustable type for additional performance. You both have good points for the different applications pertaining to Olds engines.
Old Oct 24, 2017 | 04:45 PM
DZAUTO's Avatar
Sorry I mentioned it.
Old Oct 24, 2017 | 04:54 PM
Well, bold, all caps, italics, and a dozen exclamation points...
brownbomber77
Dec 28, 2021 06:09 AM
olds 307 and 403
Sep 23, 2014 10:48 PM
rkk69olds
Apr 3, 2013 04:10 PM
Chesrown 67 OAI
Jun 22, 2011 06:03 AM
geckonz08
Feb 24, 2010 12:56 AM
