455 in a 72 cutlass convertible
Hello,
I'm planning on installing a 455 into my 72 cutlass to replace the tired the 350 thats in there now. My question is will the motor go in without any modifications to the ac unit? I would still like to keep my unit as it works fine and I'll need it during the California summer days coming up.
Just drop it in and drive away. Use the 350 motor mounts and everything else off the 350. The pulleys and water pump, unless the pump on the 455 is the exact same length. Your A/C brkts and P/S brkts will all bolt on. Hoses, fan, bolts all the same. If your 455 has exhaust manifolds, great, best to use them.
You will have to rework the head pipes to the manifolds, muffler shop no big deal. You may have to upgrade your radiator.
Gene
Gene
Hey Gene,
Your timing is perfect. John and I were just talking about you thru pm. I'm thinking of buying a 455 from him because I'm having a tough time finding one here in the bay area for a decent price. Would you happen to know where I can find one?
And thanks for the info on the fitment of the 455.
Must be the day for contemplating engine swaps, because I logged on to ask the identical question for my 72 Supreme Convertible. Also, is the Turbo 350 in stock form strong enough to handle the 455, or should I (we) look for a Turbo 400 also?
Engine mounts,
64 to 68 all the same, small or big block
69 to 72 small block OLDS, brkt and mount
69 to 72 Big block OLDS, brkt and mount
These are all for "A" body Cutlass, not full size car.
some places list RT and LF mount, but I have never seen that.
Gene
Gene
I'd prefer a complete drop in. Kind of just want to drop in and drive. I'll build it up later.
"If you are using 350 frame mounts use 350 engine mounts. If you have 455 frame mounts use 455 engine mounts. Either will work as long as frame and engine mounts match."
yea this subject seems familiar , doesnt it ? I wish I had the money to get my 455 rebuilt... my 350's engine knock seemed be non existant today for some reason , im hoping i can fix it this summer.
For future reference (yes, this is a sticky already):
https://classicoldsmobile.com/forums...tion-list.html
1966 Oldsmobile Ninety Eight Turbo Sedan - $2499 (san leandro)
May have found what you needed its on Craigslist and in very good condition, pull your combo and switch them out and then sell the car to recover some if not all or more of your money. Hope this helps out!
ros6872
Oct 30, 2015 09:41 AM
ros6872
Oct 31, 2014 05:04 PM
70SXchris
Feb 24, 2012 05:02 AM
70SXchris
Mar 25, 2011 09:31 PM
