455 6" Waterpump questions..
I'm wanting to know if there is multiple Waterpump pulleys for the 6" long Waterpump? I've got a 5 5/8" , wanting to see if there's a larger diameter pulley, thanks in advance
There's a number of pulleys made from 1964 to the 1980's that will bolt up but they may not line up. They may only be off by half a groove width, but that may be enough to throw belts or wear them out really fast. It's best if you can get a matched set, or tell us what the code is on your crank pulley so other members can try to match it.
John
John
Okay folks, I've got some measurements of the 3 groove Waterpump pulley, ALL FROM THE FRONT OF THE PULLEY NOT THE BACK MOUNTING FACE- so overall front to rear 3", not using the first pulley groove, from the front of the pulley to the 2nd groove is 2 1/8" the third groove from the front of the pulley is 2 5/8" overall diameter is 5 5/8" I need a larger pulley if y'all can help me with what stamped code or if you have one that matches them measurements, thanks I don't want to remove the pulley till I get another, thanks
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
