455
Old Jun 19, 2012 | 09:08 PM
sammy's Avatar
Sammy70 455 Supreme
455
Is an in line fuel filter necessary, and if so what kind would you recommend?
Thanks,
Ted
Old Jun 19, 2012 | 09:22 PM
Ted, they never had them from the factory. But if you want to put one in that's totally up to you. I put one in my 83 Regency. All it did was increase the mtce of changing filters. Although I will say the carb filter was cleaner for longer periods of time. If you want the stock look though, better to hide the filter down low somewhere close to the frame where the rubber line joins the metal one coming from the tank.
Old Jun 19, 2012 | 09:28 PM
Intragration's Avatar
It's not a bad idea, especially if you're running something other than a Q-jet. Make sure you use good clamps and check them at the change of season too.
Old Jun 20, 2012 | 07:08 AM
The problem with this idea is it's a pain in the butt, and you have to pinch off the line to change it! There is nothing wrong with adding an inline filter, it's cheap insurance!
Old Jun 20, 2012 | 08:47 AM
Run to Rund's Avatar
I don't recommend rubber lines up at the carb. I'd use a filter, even if a screen type from Jegs or Summit, that uses brass fittings on the ends so you can use steel lines to it.
Old Jun 20, 2012 | 09:46 AM
1965cutlassragtop's Avatar
are you talking before the fuel pump or after?? i don't think you were being exactly clear....
normal street setups are usually:
sending unit w/ in-tank FILTER sock -> pump -> in-line FILTER -> carb
racing or high HP setups are usually:
sending unit w/out filter sock -> in-line FILTER -> pump -> in-line FILTER -> carb
i believe you are asking if an in-line filter is needed between the tank & pump. so, if you remove the sock from your sending unit, or run a performance sending unit without a sock, then yes, you need an in-line filter before the pump. if you are using a filter sock on your sending unit, you can add an in-line filter if you really want, but it's not needed. you would then have a 3rd filter in your system, adding maintenance, as mentioned above. some may have different opinions about adding a third filter. but you DEFINATELY should have a filter before the pump and after, at least 2 filters all together.
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
