442 Engine Block ID
Old Dec 5, 2012 | 05:13 AM
Polebridgemt's Avatar
442 Engine Block ID
Just acquired a new project and my first Olds! A 1970 442 W30 Hardtop, partially disassembled, very solid, and 95% all there! I am trying to fully understand what it is that I have. I was hoping for a matching numbers car; however, I am unsure about the engine. The stamping on the block doesn't match the VIN. What I have is this in two lines as I have shown here:
L70SB
4311
Can anyone tell me what this code means? The block is indeed an "F" cast block, I just don't know what the significance of this stamping is.
Old Dec 5, 2012 | 06:17 AM
Where did those numbers come from?
Do you have any pictures?
Welcome to Classic Olds.
Old Dec 5, 2012 | 06:57 AM
Originally Posted by Polebridgemt
L70SB
4311
Yeah. If that's on the VIN derivative pad on the forward LH side of the block, it means that you do not have a numbers-matching block.
Old Dec 5, 2012 | 09:59 AM
Thanks for replying!
Joe,
Unfortunately, I had assumed that we didn't have a numbers matching engine.
And yes, the code is on the VIN derivative pad forward left corner. Do you have any idea how to decipher the code?
Old Dec 5, 2012 | 10:18 AM
It's not in the standard automotive format, so its probably marine or industrial, but I would bet that the "7" is an application code (Olds is 3), and the "0" means 1970.
I have no experience with these, though.
Old Dec 5, 2012 | 10:26 AM
Yes, the automotive VIN derivative format is well defined as it was federally required. I suspect the block you have is originally from a marine application, or possibly a service block with some shop's stamp. Again, the stamp would indicate that it was not originally from a factory-installed automotive application.
Old Dec 5, 2012 | 10:28 AM
By the way, it's not unusual for a W-30 (or even a 442) to have a replacement motor, since many of these cars were seriously beat on when new.
Old Dec 5, 2012 | 02:06 PM
So, knowing that I don't have an original motor, what would be the best way to proceed with the restoration, should the motor go back as close to stock as possible, or should the engine be built up for even more performance? What would bring more value to the car?
Old Dec 5, 2012 | 06:16 PM
That will depend on what your goals for the car will be. Its not hard to improve the performance and have a stock looking engine. Technology has improve over what was available 40 plus years ago. What do you hope to accomplish, whats your budget, and how important is the stock look? Same questions need answered about the rest of the drive-train (transmission, rear-end, exhaust, etc.) Fill in those spaces on your "build sheet" and people here can better assist you. BTW, there ain't no feeling like Oldsmobiling!
bocoogto
Aug 26, 2023 06:09 PM
MyPaceCar
Jun 15, 2014 07:43 PM
olds4life
Feb 9, 2010 08:48 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
