425 Fuel Pump Source?, or electric?
Old Jan 13, 2023 | 07:25 AM
Gauchobyte's Avatar
Hi: My mechanical fuel pump for a 425 failed again, so I have some questions:
a) How many miles should these pumps run?
b) Any Brand and/or source for buying them?, I usually buy from Rockauto the Carter brand.
c) Should I consider to swatp to electric?, i understand there life span is much longer, any drawbacks?
Best
Old Jan 13, 2023 | 07:36 AM
edzolz's Avatar
Is the gasoline a mix with ethanol where you live? If so, the fuel is probably making the fuel pumps fail faster because of the alcohol destroying the rubber parts inside of the pumps. If you go to an electric pump make sure it is ethanol compatible.
Old Jan 13, 2023 | 07:39 AM
Gauchobyte's Avatar
Tx for the info, Here in Argentina by regulations all gas has to have at least 12% Ethanol.
Old Jan 13, 2023 | 07:48 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I would go with a new mechanical pump. It is a lot easier, and I think Carter is a good brand. There is plumbing and electrical work to do with the electric pump. And to be safe, you need to include a fuel pressure cutoff with the electric pump for safety's sake.
Old Jan 13, 2023 | 08:19 AM
therobski's Avatar
X2 on what redoldsman says, replace the mechanical stock unit and happy motoring..There's plenty available.
Old Jan 13, 2023 | 08:20 AM
66-3X2 442's Avatar
If your car has a return line a Carter M4516 is a great pump.. It's one of their Muscle Car Series units.
Old Jan 15, 2023 | 01:24 AM
Ozzie's Avatar
I'm wondering how long your pump lasted before it failed. It seems like Rock Auto & a Carter pump would be a good combination.
In USA there are some places that have lifetime warranties on their pumps. They still might fail, but you'll only have to pay for it once.
StarRacer
May 10, 2021 09:59 AM
Sircajun
Sep 15, 2018 11:05 AM
drjr56
Oct 7, 2017 06:37 AM
toymobile
Jan 8, 2017 08:54 AM
DAN76
Oct 10, 2008 08:57 AM
