425 Compression Question.
#81
So, you ask questions demand answers in another guys thread, right? Isn't this the part where you start another thread?
"How can it be done by "degreeing" the cam?"
I never said that it could, I said,
Originally Posted by captjim
........ I also understand that some builders do it to verify cam tunnel location and align bore straightness.
Last time I heard it IIRC was Joe mOndello on the Horsepower TV show.
#83
Perhaps I know a few quicker, less expensive, and/or more accurate ways to get the job done.
If so, it has nothing to do with any "experience" or "credentials" I might (or might not) possess.
It is a simple statement of fact.
Nothing more, nothing less.
Only took a couple of minutes. Nothing there that cannot be found elsewhere on the internet.
Norm
Norm
#84
In such instances, ones failure to correct an error, a typo, BS, or to otherwise clarify it, should always be called into question.
Let us take a closer look at what you did say:
Norm
#86
I dug all through my files, certain all the while that I would find all of the paper work I needed to give you guys the information you were asking for, but the info on the important stuff such as the cam, pistons, lifters and springs are nowhere to be found. I believe they're all together, where ever they are. I believe I kept them out somewhere more accessible so they wouldn't get lost in the abyss of storage boxes and old documents, but apparently that plan backfired. I have since moved to another house and moved my body shop and these apparently got lost or misplaced along the way.
The good news is that things are looking a bit better. I found a small vacuum leak in the hose that runs through to the ac controls.
I've also been working on the timing, as well as doing my best to educate myself about the subject. I think my limited understanding of the matter has caused me to err on the side of conservatism. I still don't really understand it completely, but here is what I have so far.
Idling at about 850 rpm with vacuum advance unhooked and plugged I'm looking at 14 initial and 32 overall. All in by 1800 rpm
bumped that up to about 18 initial, 36 overall in by 2000. It seems to like this much better. I didn't notice any detonation, but I'm a little apprehensive because I'm not sure that I'd recognize pinging if I heard it.
Is it clearly audible? Can I detect it better by maybe holding a wooden dowel to the cylinder head and listening to it? It seems like it would like even more advance, but how much is too much? Is it like this because of the camshaft choice?
I didn't get it out to drive it yet, but I put my foot on the brake and started to push the gas pedal and the tires, or I guess I should say tire, broke free and started spinning with little effort. Before, it was all I could do to get those suckers spinning. This is getting closer to what I'd hoped to get from it. I'll mess with it a bit more and come back with more questions.
I appreciate you guy's continued help. It would be real easy to get frustrated and maybe give this engine building thing up if it weren't for guys who were willing to point me in the right direction when I encounter something that is beyond my knowledge base and definitely outside of my experience. I've spent my whole life making these cars pretty, it's time I learn to make them go.
#90
I know, I know. I haven't had anyone to help me with that. Tried to do it by myself, I could see it on a few cylinders, but I need someone to crank it for me so I can see the gauge clearly. Hopefully I'll have that tonight or tomorrow.
#92
No, I thought it was Norms thread.
Did you use a timing chain with 3 key way slots? It's a little confusing and I have made that mistake before. The keyway slot has a dot next to the keyway and on the outer edge. So there is 2 dots on the lower gear.
Also if the seconaries aren't working your car would have a huge HP loss. Check out the carb while it is running and wacth the action of the carb and make sure you have the cable adjusted to get full throttle with the gas pedal.
Dave
Dave
#93
#95
#96
Ok, it's done.
Did the first 3 cylinders down the left bank and realized that the adapter I was using was probably a bit long and therefor may not be seating al the way in, so I took it off and continued the test with the same results.
130-135 on all cylinders. Because of the adapter situation I went back and tested the first three again. This time #1 is reading 160. Ran #1 again, 165.
tested all of the other cylinders again. 130-135 on all, except #1.
#97
last time I took the plugs out they were all fairly black. I cleaned them, put them back in and adjusted the idle mixture. This is what i pulled out this time. From right to left - 1, 3, 5, 7, 2, 4, 6, 8.
#1, the cylinder with the high compression is the black one.
#98
did you do the comp test with a warm engine, throttle wide open? did you watch the gauge¬ice how fast the needle moved? if you did it right, that reading is horrible&thats why its a dog. the motor has a mechanical problem.
#100
My 71 engine with 8 to 1 compression has the same compression numbers. That seems strange that they're even except for #1. The video could show how smooth the idle is, also show pulling off the breather and or oil tube cap while it's running to check for blowby, how fast it revs up, also a shot of inside the car driving with the power on. Does the cars exhaust smell like fuel, like it burns yoour eyes? How old is the fuel? Did you dial in the cam, that may tell us something. Does it miss at higher rpm's? Did you ever try another carb? Did your lower timing chain gear have 3 slots for the keyways? You could still have the dots lined up and have it on the wrong keyway. I did it once years ago and bent a valve but I don't think it would run having the chain in the wrong keyway with the dots lined up.
Did you ever try moving the distributor to a more advanced position? maybe your light is defective. I'm reaching for anything and running out of suggestions.
Dave
Dave
#101
I think we've covered most of the stuff you mentioned. I've already admitted that I didn't degree the cam, just installed it dot to dot. It is a 3 key gear installed straight up. The timing is much better since I've gotten some help here with that and it runs/sounds good. Good oil pressure. No misses, good throttle response. I'll make a video and post it soon.
I'm just afraid with the compression numbers I just got that I'm going to be opening this thing back up to find out if the problem is in the machine work or the pistons I used that I don't have the specs on. I might just weekend cruise it until next spring. I can't afford to tear back into it right now. I know the machine shop is competent, but didn't verify the accuracy of their work. I would certainly like to know why I would I have compression so much lower on all but the #1 cylinder?
#102
Maybe you should get a stop watch and time your 0-60 just to see where your really at. Or even a 20-70 if you can't get out of the hole without spinning.
Maybe drive it over to the place that did the machine work and see if he can be of any help. He wouldn't want an unhappy customer even if it may not be his fault because his name is on the engine. I'll bet he'll take a look.
#103
In the initial post,
"Block was bored 40 over, stock compression pistons, heads rebuilt stock + hardened seats and SK-247-SP springs. Put in a JM-22-25-10 cam"
IMO, this is your problem. Big dish pistons short on compression height with a thick replacement head gasket making the Cr too low which means the cam is too big. I know you looked, but I would really try to find out which pistons are in it before tearing it apart.
#104
Takes about 9 seconds. Getting off the line without spinning the tires is NOT a problem. Getting the tires TO spin is the problem.
#105
I went by the shop of the guy who helped me assemble it today and I thought I got lucky and found the box with the old pistons in it, but turns out it was the box for the Ford 390 pistons I used in my buddy's car.
#106
#108
#109
Compression is low, but very consistent, with the exception of the number one cylinder which I believe to be higher because of the fuel being dumped in there. This also being why the plug from the #cylinder was the only one that was black. Does this make any sense??
Either way, I think it's time to tear it down and begin again. Oil pressure is now dropping to almost zero once the engine reaches operating temp. I checked the oil and it's got gas in it. Could this have worn my rings, bores causing the compression loss?
I think I've acquired enough information here to enable me to do it right this time. I always did learn better the hard way.
#110
fuel wash on a fresh rebuild can cause skirt scuffing which could lock the rings up. you wont know until you take it apart. since you have no oil pressure, that should be soon before you make it not rebuildable. i would try to figure out why its dumping excess fuel while its still running.
Last edited by gmrocket; July 18th, 2009 at 09:43 PM. Reason: why do i have give a reason to edit
#112
This is way beyond my technical knowledge so should probably keep quiet, but i was running the 750 edelbrock on my 65 425 (delta 88) and had the same "lazy" issue.
I've since spoken to loads of people who have had this carb in the past and most have changed it. I bought a rebuilt quadrajet from a 350 Cutlass and simply bolted it on without tuning and already it's a completely different car!
#113
#114
i think they were talking the carb. if you have a tight converter¬ much gear, the e brocs do tend to bog. its the air valve door flipping open to fast for the engine, its an easy fix to tune it back to where it with run without the hesitaton. e broc has an excellent tuning book that comes with their carbs&it goes through every tuning step in detail. you an email them&they will send you the complete manual in a file. i have a 750 on my car with a 403&when i had a tight factory 13 converter with 3:73's it initially did the hesitation. i tuned it out&it pulled great from a dead idle. then when i put in 4:56's and a 10 3500 converter it runs like a champ, 11.87 113+mph they are good carbs
#115
i think they were talking the carb. if you have a tight converter¬ much gear, the e brocs do tend to bog. its the air valve door flipping open to fast for the engine, its an easy fix to tune it back to where it with run without the hesitaton. e broc has an excellent tuning book that comes with their carbs&it goes through every tuning step in detail. you an email them&they will send you the complete manual in a file. i have a 750 on my car with a 403&when i had a tight factory 13 converter with 3:73's it initially did the hesitation. i tuned it out&it pulled great from a dead idle. then when i put in 4:56's and a 10 3500 converter it runs like a champ, 11.87 113+miles per hour they are good carbs
#116
This is turning into a very informative and interesting thread! It's amazing how much I've learned already! I'll be paying close attention as I'm considering putting a '66 Toro engine in my '65 Vista. I hope this one keeps rolling....
#117
I've learned alot also. Just wish I could have learned it BEFORE it put the engine together.
Cart, Horse??
#119
Thanks. Body & paint I don't have a problem with. It's this engine stuff that's new to me. I do need to get some new pictures. With the exception of the upholstery & a/c plumbing it was pretty well finished. Now it's time to un-finish it and finish it one more time.
#120
I'm convinced that the problem is an internal mechanical one based on the results of the compression test so I am preparing to pull the engine & tear it down. I'm going to collect the tools I'm going to need that I don't currently have so that I can check things myself rather than blindly taking someone else's word for it. Is there anything else I should check BEFORE I pull it apart? Any information I could gather before hand? Or since we know that the compression is poor, should the next step be dis-assembly?
Also, I want to be prepared if it turns out the pistons are the source of the low compression. Where can I go to get the correct ones at a reasonable price? I see lots of 455 stuff on Jegs, Summit, etc, but nothing for the 425. If I have to drop $500 on new pistons, it's going to seriously hold up the project. I want to be prepared so I can have this thing out, built properly and back in in as little time as possible.
