425 Cam bank angle
Old Jan 26, 2008 | 12:27 AM
raymondh36965
Guest
Posts: n/a
425 Cam bank angle
I have a 425 Oldsmobile and am trying to figure out what cam bank angle I have whether its a 39 degree or a 45 degree. Can anyone tell me a 100% sure way to figure this out? Also is there anyway of telling if the heads on the engine are the origional heads that came on the engine. Here is some of my eng info.
Block casting 389244D
Heads Casting B 389395
Lifter diameter is .842
Old Jan 26, 2008 | 01:49 AM
88 coupe's Avatar
Junior Member
Originally Posted by raymondh36965
........ a 100% sure way to figure this out? ........
With the manifold off, put a “straightedge” on the intake surface of the head. Measure the distances (above and below the head) between it, and the pushrod.
If they are the same, you have 45° bores, if the bottom is closer, than the top, it's 39°.
I don't remember the number, but it's more than obvious.
Norm
Old Jan 26, 2008 | 03:53 AM
raymondh36965
Guest
Posts: n/a
425 Cam bank angle
Norm
Okay so when you say measure the distances above and below the head i am a little confused. When i measure the distance below the head do i measure from the bottom of the head to the top of the lifter bores, and when i measure above the head where do i measure from the bottom of the head to the top of the head? Let me know when you get a chance and thanks for helping me out on this.
Ray
Old Jan 26, 2008 | 07:08 PM
88 coupe's Avatar
Junior Member
........ Measure the distances (above and below the head) between it, and the pushrod.
Between the "straightedge" and the pushrod.
Norm
Old Jan 27, 2008 | 07:04 PM
70Wcars's Avatar
This may sound complicated and Norm's method is dead-on accurate, but here goes.
According to Mondello's engine tech book, which has been questioned for its accuracy, a block cast with your number and the .842 lifter will be a 45 degree block. A block with your number and lifter size will be a 39 degree block IF you also have a " drill spot " on the block. I have worked on a couple of these and the drill spot is located on the small raised part of casting that is in front of the oil fill tube and goes from the base of the Intake manifold end-rail forward to the back of the water pump and looks like someone started to drill a 1/4 " hole and stoped after about a 1/16 th of an inch of depth.
Hope this is not too confusing...I still trust Norm's method the most.
Danny
Old Jan 28, 2008 | 08:01 AM
88 coupe's Avatar
Junior Member
Before he retired, Joe sold a tool for that purpose. Don't know if the new guy still sells it, but the difference is easy to see.
The scan is from a '97 Mondello catalog.
Norm
Old Jan 29, 2008 | 01:25 PM
olds-cutlass's Avatar
Hi, i'm new here, and i live in Austria this is an small country in Europe, i do have the same problem whit the 425 BB i want to put it in an 79 olds cutlass calais, i did found this photo on the internet page from oldspower.com here ist the complet link http://www.oldspower.com/photopost/d...0/425block.jpg as you can see there is an drill spot on the left near the oil tube, i hope that this is what you mean, i'm not very sure, hope that someone can tell me for sure if this is that drill spot! I allso do have 0.842 lifters and the block castingnr is 389244 but my headnr is 548 and it is an C head with small 2.000 intake valves. I hope that Ray will find the drill spot to. Berend
Old Jan 29, 2008 | 04:19 PM
88 coupe's Avatar
Junior Member
Following is from a post at Real Olds Power.
Originally Posted by Octania
Drill Spot for sure indicates 39' CBA
lack of DS is the problem.
I actually have photos of an E block, which are ALL 39's, w/o drill spot.
The only way to tell fore SURE is to measure, as set forth above.
here's a drill spot on a Toro D block:
Here's one guy's method of ck'g for exact 45-ness:
I have a special tool with lifter bore size [both sizes] and a 1/4 hole at 90' to the lifter bore, shown here exhibiting a non-45' block:
Norm
Old Jan 30, 2008 | 10:46 AM
I do have that drill spott on my 425 as seen on the photo i did sent, my engine daycode is 298 on the back of the block near the distributor, witch means it is an 1967 OKT 25 or 26 built 425 the vincode on the right cylinder is P071391L. P= 1967 numbers are assemblycode and L=low comp.9.0:1 so ist an 300HP 425 this is what the american V-8 engine data book says, it came out of an jetstar with an 2BB carb. Hope you are right and ist is an 39 degree block, but i will measure it to by sure.
Ray, yes i know about mondello, i will order there tech catalog! i do know that they are expensive, perhaps somebody can tell my an other shop for olds 425 and A/G body parts but they schould sent there parts to Austria Europe! Thanks to Norm for the photos, they are clear and now i know how to messure it.
Berend
Old Jan 31, 2008 | 01:34 AM
88 coupe's Avatar
Junior Member
Originally Posted by olds-cutlass
........ another shop for olds 425 ........
Contact one of the following Olds specialists. Any one of them can help you put together the combination that will be best for you.
BTR Performance (Bill Trovato)
http://www.btrperformance.com/
Dick Miller Racing (Dick Miller)
http://www.dickmillerracing.com/
Greg’s Performance (Greg Godon)
http://members.aol.com/gregsperformance/
MJ Proformance (Mark Smith)
http://www.mjproformance.com/
Rocket Racing and Performance (John Stolpa)
www.rocketracingperformance.com
Dave Smith Engineering
25078 Road 196
Exeter, CA 93221
(559) 562-3500
Norm
Last edited by 88 coupe; Mar 23, 2009 at 07:47 AM. Reason: Removed one of the vendors.
Old Jan 31, 2008 | 12:49 PM
Thanks again Norm, for your information.
Berend
Old Feb 3, 2008 | 10:46 AM
Hi, yes its an rare 39 degree 425 i did measure it the way Norm shown on the photos. The drill spot is there near the oil tube shown on the photo i did sent from the oldspower.com page. Hope this wil help others to.
Berend
Old Feb 3, 2008 | 01:50 PM
raymondh36965
Guest
Posts: n/a
Cam bank angle
What did you stick in the lifter bore to measue it?
Old Feb 10, 2008 | 01:24 PM
Hi, i did presst hard with an straight piece of metal on the lifter, cam muss still be in the engine, and did take an other to find the richt angle. so you don't have to stick something in to the lifter bore, if you push hard enough on the lifter so it wil, muss be straight on the lifter than you can measure the angle with an other piece of metal. did try to put some fotos on here but did not work so far, will try again tomorrow, do have'n new computer and this thing is not doing the way i want to!
Berend
Old Aug 15, 2009 | 09:16 PM
hotrodpc's Avatar
45 or 39 degree visual inspection
For those who find this thread and need this info, here is a pic that will show how to visually tell the differance. Of course measuring is ALWAYS the absolute way to tell, but the pic also makes it fairly simple.
Old Mar 22, 2010 | 05:11 PM
jc83's Avatar
i just put up a post about 39*vs.45* B Heads..this thread was helpful to me because all i have is the heads & not the block i do however have a 455 1973 block that i will place my B Heads onto and see what happens pushrod alignment wise..
Old Mar 23, 2010 | 10:09 AM
507OLDS's Avatar
To ad to the this info,I have found 1966 to be the only year that you could get a 425 with both the .842 lifter and the 39* bank angle.However,not all 66 425's were like this.All of the ones I have/had came out of 66 Deltas.All of the other years of 425's(65,67) either had the .921 lifter,or the 45* bank.I hope this helps.
Old Mar 23, 2010 | 10:33 AM
aliensatemybuick's Avatar
"me somebody" site member
I would swear that most non-Toro '67 425 motors were small lifter and 39 degree, based both on personal observation (admittedly small "sample size") as well as what I have heard of other people's experiences.
Old Mar 23, 2010 | 11:02 AM
hotrodpc's Avatar
I'd also have to differ. I had a 67 425 block that was both small lifter and 39 degree. Standard bore block, just sold it a few months back for $200.
Old Mar 24, 2010 | 05:45 AM
507OLDS's Avatar
I'm not saying it wasn't done.Just from my experiences with these,all of my .842/39* 425's came from 66 deltas.All of the 67 425's that I had came from Toros,& had the .921 lifter.I sold them all to someone who uses them for a stocker class.I just got one of my 66 425 blocks out last night & looked for the drill spot,but I do not have that.It's leaving friday,so I had to do it anyway.
Old Mar 24, 2010 | 06:10 AM
hotrodpc's Avatar
My 67 with small lifters and 39* also DID NOT have the drill spot.
lemoldsnut
Tech Editor's Desk
Jun 29, 2015 10:26 PM
jhoppeolds
Aug 21, 2014 05:26 PM
Octania
Jun 1, 2014 12:21 PM
Old Olds Fan
Oct 2, 2013 05:19 AM
nonhog
Aug 25, 2009 03:59 PM
