403 rebuild
Old Sep 30, 2014 | 12:43 PM
Crockett 999's Avatar
403 rebuild
Guys, can anyone tell me if I can get any flat top pistons for a 403 ??? And, if so would the 7a heads off a 350 fit the 403 ???
I,be been on speedpros website and they only mention said pistons for 350 or 455s
Old Sep 30, 2014 | 01:01 PM
cutlassefi's Avatar
Here's a flat top piston for a 403;
https://www.uempistons.com/index.php...bd59cdeb4cc379
With a stock 7a head it will yield approx. 10.7:1, probably a bit high for an iron headed application on pump gas.
And to get those heads to fit you'll need to drill out the head bolt holes to 17/32 and I believe enlarge a dowel hole as well.
Just an fyi, this should be in the small block section, not big block.
Old Oct 2, 2014 | 08:37 AM
Cheers mate, out of interest are you running a 350 with an Eddy airgap intake ? We,re gonna rebuild the 350 now with flat top pistons, any suggestions ? PS if I was any good with computers I would move this to the small block section, but I ain't.
Old Oct 4, 2014 | 08:27 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The 403 with the pistons Mark listed would be great with Procomp aluminum heads. You can use cast replacements with the 7A heads for 9 to 1 compression. The 403 is a small block, just so you know.
Old Oct 4, 2014 | 01:41 PM
cutlassefi's Avatar
Any chance of giving more info? Gear, car, tranny, the rest of the combination, wants etc.
Old Oct 5, 2014 | 09:20 AM
Not sure of gear ratios, how do we find out ? I know the car is just about standard in all respects, 3 speed auto, 350 rocket, is your intake a performer airgap ? I can't see these listed anywhere for an olds s/b.
88hurstolds
Jan 20, 2020 11:39 AM
kips70cutty
Jan 17, 2014 03:45 PM
85cutlass6.6
Aug 10, 2011 02:28 PM
1979403ta
Jun 30, 2011 06:17 AM
dhartley72
Oct 28, 2010 05:54 AM
