4 speed crank?
Old Nov 21, 2021 | 09:56 AM
REO442's Avatar
Smile 4 speed crank?
So is this the candidate for 4 speed bushing upgrade, I need the specs to make it happen. Machine for bearing or bushing, want the best option for reliability.
Old Nov 21, 2021 | 10:37 AM
It's a nodular AT crank, no different than any other one the factory used to machine the MT pilot bearing recess.
Old Nov 21, 2021 | 05:51 PM
2blu442's Avatar
Here's an old thread that has the details on how to drill/cut the crank for a pilot bearing or bushing. Joe, maybe the drawing on this thread would be good to make a sticky for?
Is this a manual trans. crank? - ClassicOldsmobile.com
Old Nov 22, 2021 | 06:44 AM
VORTECPRO's Avatar
Here you go-I do this operation if you can't find someone where your at.
Old Nov 23, 2021 | 06:30 AM
Run to Rund's Avatar
The above is correct for the stock Bower 1709 bearing or Dorman -023 bronze bushing. I like to use either a Chevy bushing or Auto Gear (better material), and get the crank machined for it, to the depth needed for good engagement to the transmission input. If using an SFI bellhousing and block plate, the transmission will be farther away (usually about 0.14")..
Old Nov 23, 2021 | 11:45 AM
REO442's Avatar
Will this spec drawing be used for the bushing or the bearing?
Old Aug 10, 2023 | 04:35 PM
TOC's Avatar
TOC
Andy, great pics of the way things go together for the clutch assembly.
I did find out that since my car was originally an ‘automatic’, it doesn’t have the tab that’s welded to the frame, to mount the bell crank to. But I found the tab at The Parts Place and ordered it.
it appears I have all of the pieces for the clutch/pedal assembly.
Thanks again for the photos… very helpful! May need more if you don’t mind.
Tom
Old Aug 10, 2023 | 04:38 PM
TOC's Avatar
TOC
Reo, I’m pretty sure it will be a bronze bushing.
Tom
Old Aug 10, 2023 | 05:27 PM
Andy's Avatar
Tom
no problem, Tom, feel free to PM me and I’ll send you my phone number
smits
Jun 21, 2021 04:36 PM
cutlass1972s
Jan 2, 2018 03:46 AM
David DeCan
May 25, 2016 11:50 AM
s i 442
Jul 14, 2013 04:41 PM
Propaneking
Jul 27, 2012 06:09 PM
