4 Corner cooling project pics & Air Cleaner envy!Hardcore Olds Stuff!
Old Sep 5, 2009 | 07:16 PM
BIGJERR's Avatar
I bleed Oldsmobile
All right got it done up,It was pricey for sure and maybe unessary but Its done,The Victor intake is a monster,At least I have a use for the cowl hood now!!!!!!!!! Ready for some huge air cleaner envy????
Old Sep 5, 2009 | 07:48 PM
citcapp's Avatar
Nice, it looks great. What do you think of the performance of the Victor manifold and what cfm carb are you running if you don't mind my asking. I am trying to figure out what combo to run on my 455 build for the 48 Olds
Pat
Old Sep 5, 2009 | 09:14 PM
BIGJERR's Avatar
I bleed Oldsmobile
Talking
Pat
First fired it today,Just did a intake change,Torker to Victor and the 4 corner cooling deal...........I will try it out at the Byron BOP Race Sept 12 -13 or a little street action tommorrow for a seat of the pants test,BTW box stock 850 Holley DP.............Jerr
Heres a link to my combo...
http://72.22.90.30/phpBB2/viewtopic.php?t=12112
.......Cheap and reliable and been the car 7 years next April with the last 4 being a NOS test bed for me......I sure cant complain......
Old Sep 6, 2009 | 07:00 AM
cutlassefi's Avatar
4 corner
Nice setup!! But how does it bypass when the t-stat is closed? Or are you not running one? Thanks.
I'd be interested to know about the performance of that manifold as well.
Old Sep 6, 2009 | 10:07 AM
citcapp's Avatar
BigJerr,
Please explain the cooling setup and the reason for it. Its new to me, whats the reasoning behind it. Please share.
Pat
Old Sep 6, 2009 | 11:43 AM
BIGJERR's Avatar
I bleed Oldsmobile
Heres seems to be the best info I got.......
Jerr, the pump pulls water from the bottom of the radiator, pumps it into the block, from the block to the heads, and from the heads to the water cross over at the front of the intake, then to the thermostat housing and back to the radiator. If you run lines from the back of the heads to the cross over at the front of the intake (or thermostat housing) it will remove the hot water at the back of the head faster and help keep the temps at the back of the head close to the temp at the front of the head where the water spends less time in the head. If you don't run lines from the back of the head to the water cross over at the front of the intake, the water has to go from the back of the head, then across the head to exit out the front water port.
Even if the temperature differences between front and rear combustion chambers are small after the engine heat soaks at the very least it will help circulate water faster out of the heads. So, there is no downside to doing it other than the cost of plumbing.
J-(Chicago)'s Avatar
Seasoned beater pilot.
RobbMc thermostat housing?
Old Sep 6, 2009 | 11:45 AM
BIGJERR's Avatar
I bleed Oldsmobile
Yes sir!!!!
Old Sep 6, 2009 | 01:58 PM
citcapp's Avatar
Thanks, that helps a lot as we know heat can be our enemy.
Old Sep 10, 2009 | 03:27 PM
jims2000lt's Avatar
11.52 @116
Nice set-up and Olds. I'm running about the same set-up and was figuring that intake is too much for my combo. What do you think from your expirence? This is my current set-up at 3500#s with me in it.
.40 over 455
Lunati hyd cam. 241 dur. 545 lift. 110 lsa
E-Brock heads
Harland Sharp roller rockers
Torler intake 800 holley with proform main body
9.8 to c.r.
2" super comps to 3' pipes to spintech ELs- no tailpipes
th400 3500 stall manual vb
3.42 gear with ssm lift bars
Hoosier QTPs 28x 11.5
Best so far 11.60 @116 1.57 sisty foot.
I figured I would ask here cuz I cant get registered on ROP. Its been like 3 months since I first registered. Thanks
Old Sep 10, 2009 | 07:56 PM
BIGJERR's Avatar
I bleed Oldsmobile
.40 over 455
E-Brock heads
9.8 to c.r.
Thats more motor than Iam running,I would think more gear would help some other than that 11.60s are a pretty stout number................Jerr
dz442
Aug 21, 2013 07:35 AM
1970cs
Jan 25, 2012 05:38 PM
69CutlassAlex
Dec 2, 2011 08:01 AM
bourbon454
Apr 19, 2010 07:21 PM
StickW31
Feb 25, 2010 01:14 PM
