394 vacuum line off of pcv?
Hello-
Just recently purchased a 63 Starfire convertible. Noticed the vacuum line is missing off of the pcv valve-passenger side valve cover. There are two ports-one big 3/4" hose that goes to the front snorkle of the air cleaner and there is a small 1/4" port that does not have a vacuum line on it. Does anyone know where this vacuum line would connect to? It is a 394 Starfire engine...
Depending on year it can go to a vacuum fitting at the rear of the carb throttle plate or to one on the intake manifold behind the carb.
If it's not connected to vacuum source, the plate inside the PCV valve will never rise off its seat and there is no crankcase ventilation. When the plate rises, the blowby gases get sucked into the aircleaner snout and go back thru the carb for reburn.
I always thought it was a weird design but I guess it worked in its day.
Service Manuals
Check out what Yellowstatue said, 'cause if you were doing things step by step you would have used the Service Manual first and Classic Olds second.
Thanks for the phone number of the person in Seattle as we were looking for a 63 yoke. We contacted John and he gave us his friend Jerry's phone number (Who owned a 63' Starfire Convertible John had sold to him several years previous) and purchased our 63' Starfire from him and got the yoke from John the same day.
My 63 394 Super 88 had no vacuum line going to the PCV. There is a You Tube video showing vacuum line routing on a 63 98 with PCV vac line coming off rear carb base port.
When I hook it up that way it does not just open the plate but sucks full vac out valve into valve cover.
Makes me think the valve is bad. It should just open the plate and allow crankcase to vent up into the air cleaner. Right? Other wise I just have a big vac leak with unfiltered crank case air entering carb base.
I have since hooked up the vacuum line port from the back of the base of carb. It seems to work fine as the big tube goes into the front of the air filter housing...No problems since. I did find out however that the 394 that I have is out of a 62 98. So it is possible that in 63 may be different.
'62 !!!!
Hey there trackz man; If your engine is a '62 394 the water pump housing is Cast Iron and '63-'64 394's are all Aluminum housings. Hope this let's you know what era engine you have. If you need to know the exact year of your Engine that can be explained in further detail later as it's a little more complicated......
It is good to know as if I ever need to replace the water pump.
What other differences are there that I may need to know, lets say for a tune-up? Any differences in plugs, cap, rotor, points etc...?
Del70
November 15th, 2013 02:24 PM
