394 exhaust manifold for '61
Old Oct 17, 2008 | 05:48 PM
bjtstarfire's Avatar
I am interested in confirming the following exhaust manifold part#'s for my car prior to purchasing the correct dual exhaust system that the car originally had. Today it has the xover pipe which I'll remove and add a block-off on the RH side of the manifold. The numbers seem to be correct from my research thus far and they are:
GM 579278 RH
GM 579279 LH D2
btw any part number for the manifold heat control valve that can be crossed to a new one?
The shop manual states that gaskets are not used between the C-head and exhaust manifold - is that still a valid way to install it ???
Last edited by bjtstarfire; Oct 18, 2008 at 05:48 AM. Reason: Fixed typo in left side part number
Old Oct 17, 2008 | 09:38 PM
59-59-59's Avatar
In my '61 flat rate book, I'm looking at LEFT side - 579279 and for the RIGHT side - 579278. If your looking for an exhaust manifold heat riser valve, then Fusick sells them brand new.
Old Oct 19, 2008 | 04:18 AM
Thanks 59-59-59 what are your thoughts on the gasket, if any?
Old Oct 20, 2008 | 06:30 AM
Use a gasket unless you have the mating surface on the manifold and head machined. Use anti-sieze on the bolts and torque them to spec. Make sure you retorque them after driving the car a couple of times.
Old Oct 20, 2008 | 03:48 PM
Thanks all!
KQQLCAT
Jul 19, 2010 09:20 AM
The Swede
Oct 20, 2009 01:17 PM
bbodine
Dec 18, 2007 04:24 PM
jeffrey
Nov 26, 2007 06:45 PM
KQQLCAT
Oct 29, 2007 03:47 PM
