394 engine rebuild
Old Mar 7, 2018 | 02:40 PM
KVP's Avatar
KVP
394 engine rebuild
What would be a ballpark figure for rebuilding a 394 to factory specs? Car runs well but consumes oil.
Old Mar 7, 2018 | 03:23 PM
Oldsmaniac's Avatar
Depends on who is doing the build, to pay someone for machine work, parts and labor I would say 3500. A lot depends too on what new parts are needed. If you are just dropping off the car and picking it up with a turn key ending look for 5,000.00
Old Mar 8, 2018 | 05:37 AM
KVP's Avatar
KVP
Thanks for the reply. That gives me a good idea of the $ amount to factor in regarding a car i'm considering making an offer on.
Old Mar 8, 2018 | 09:19 AM
My442's Avatar
The rebuild depends...
My experience with Olds 455 (which are cheaper to build than a 394) is a good rebuild is between $5-6K. That does not include the R&R from the car.
That is with a new cam/lifters, pistons/rings, cam bearings, main/rod bearings, water pump, oil pump, freeze plugs, rod bolts, gaskets, tune up.
Bore/hone, grind crank, resize rods, deck block, full valve job, resurface heads, magnaflux, hot tank, etc.
The costs add up fast.
Old Mar 8, 2018 | 05:12 PM
KVP's Avatar
KVP
Thanks for your response, My442.
jwedeen
Feb 8, 2022 09:43 PM
trackz man
Dec 13, 2010 12:45 PM
rodsolds
Sep 15, 2010 11:31 PM
Jody Karls
Oct 27, 2008 09:02 AM
