394 cam bolt
Old Aug 13, 2021 | 02:26 PM
64Guy's Avatar
Alex
Lightbulb 394 cam bolt
As many know I am rebuild my 64 old's 394. Today I installed the cam and put on my trimming chain. When I was putting everything together I had read there is a front bolt that needs to be installed to prevent the cam from "walking out" I have no idea if this motor had it before my ownership or if i misplaced it but i cant find it? is it a necessity? here is also a video for the play:
Old Aug 13, 2021 | 05:18 PM
BillK's Avatar
Is that your engine in the bottom picture ? If so I would suggest replacing the timing set with one that has a metal top sprocket. That 56 year old plastic is probably not long for the world.
Not 100% sure on the 394 but unless the engine has a roller type camshaft there is typically not anything to keep it from moving forward. The taper on the lobes combined with the oil pump drive gear keep it pulled to the back.
Old Aug 13, 2021 | 09:03 PM
Charlie Jones's Avatar
Phantom Phixer
I am 100% sure that Bill is right .
Install a new timing chain and gears , and you won't have all that back and forth play .
The plastic sprocket is a no no .
Old Aug 14, 2021 | 05:56 AM
Oldskeeper's Avatar
The 63 and 64 engine have the aluminium waterpump timing chain cover housing. A cam bolt that pushes against the aluminium wouldn't last long before it wore a hole into the waterpump chamber. As stated above here you don't require one.
64Guy
May 13, 2021 04:33 PM
59-59-59
Sep 19, 2019 02:26 PM
64Rocket
Nov 27, 2015 01:00 PM
Blownolds
Jul 4, 2015 06:34 PM
tjdr90
Apr 19, 2012 07:36 AM
