371 Rocket Need help
I have a 57 Oldsmobile 98 with the 371 motor. Been running fine and about a week ago I got a knock coming from the motor on the driver side. It only knocks after the motor warms up. I pulled the valve covers and fired the motor and there is NO oil going to the valves on either side. I figured it must be the oil pump. Well I put a oil guage on the motor and fired it up and its reading 35psi so I know the oil pump must be working. I am clueless now. Thanks for any help you might be able to give me. Thanks again
You may have a clogged oil feed hole up to the valve train which requires removing the rocker arm assembly and finding the oil hole in the cylinder head. A thin metal rod such as a heavy gauge welding wire and some degreaser would work
Thanks for your help. I removed the rocker and used some welding wire and I can get it to go down about 3 1/2 inches . The oild lookes to be very clean. is there a trick to get the wire to go farther down ?
For an Olds I think that is within range. You must determine if the knock is from deep within or is it a tap from a lifter or rocker. A rod knock can sometimes be pinpointed by pulling a plug wire one at a time and then rev the engine some. The noise will decrease or go away on the offending cylinder because there is no load on it from firing...
Blownolds
Dec 14, 2012 02:00 PM
