350 to 455 swap
Old Jul 16, 2012 | 07:27 PM
61reoldsman's Avatar
350 to 455 swap
I am planning on going with a 455 in my car at some point ,if you have 350 springs in the front (no A/C)now and your 455 has aluminum heads and intake will the springs still need to be changed ?
Old Jul 16, 2012 | 07:45 PM
copper128's Avatar
Lt. Buzzkill (ret.)
In my opinion, no.
There is not a huge weight difference between a small block vs big block Olds engine. The heads & intake should make it close enough that you don't need to change springs.
Of course, it's no harder to change springs after the engine swap if you decide you don't like the way it sits or rides.
Old Jul 16, 2012 | 07:50 PM
I agree, leave the springs alone for now and see what it looks like after the swap. With the aluminum heads and probably manifold, headers, you will be lightening the load of the BBO considerably. I bet it will be a wash on the weight.
Old Jul 16, 2012 | 07:59 PM
Thanks guys ,thats kinda my thoughts ,I've always wanted a 455 in my Olds and if I'm going to rebuild an engine I MAW go BIG !!
Old Jul 17, 2012 | 09:34 AM
MAW, lol!!!!
Old Jul 17, 2012 | 09:39 AM
ah64pilot's Avatar
With aluminum heads and intake you'll most likely find that the springs are still too stiff. My 350 car sat just right with a stock built 455...when I got the aluminum EVERYTHING the car rose 2" and looks like a gasser. I'm trying to fund a spring swap using QA1 coilovers.
Old Jul 17, 2012 | 09:57 AM
rjohnson442's Avatar
Mr. Johnson
My 72 originally had a 350 and still has stock springs not much of a difference once the 455 was in. maybe an inch lower. Easy swap just have to have matching motor mounts and brackets. I've heard hood clearance can be a problem, but I didn't have any and my hoods not original though.
Old Jul 17, 2012 | 10:00 AM
Intragration's Avatar
Ha ha MAW has cost me a lot of money over the years! It seems strange that the 455 with aluminum components would be that much lighter than a 350, but I guess it's possible. My 455 with an aluminum intake and no AC now resides where a 3.8 with AC used to, and it sits just about the same, but the spring rate is too low and the springs are too long, so there's a lot of float. You may want to plan on changing the springs just to take out the float and give you more control with the extra power. The ideal time to do this would probably be after you get the new motor in, and you can see how it sits and how much the front end weighs.
As for engine height, the 455 is about an inch taller, all other things being equal. Depending on which intake and spacers you have now and use with the 455, this could affect height also.
Old Jul 17, 2012 | 06:09 PM
From some of the info I gathered online it looks like the 350 weighs in around 560 lbs and the 455 weighs 605 ,not a lot of difference really and with aluminum heads saving approx
50 lbs that places the BB right there with the weight of a SB with iron heads .
Old Jul 18, 2012 | 08:31 AM
Mr. Johnson
A bare block is 400 pounds with iron heads and all accessories on its about 700+ pounds
Old Jul 18, 2012 | 04:44 PM
I'm not positive but the info I have is just for the motors no accessories ,but wouldn't the accessories add the same amount of weight for both motors?http://www.carnut.com/specs/engdim.html
Old Jul 19, 2012 | 07:17 AM
Mr. Johnson
That should be correct. We weighed mine no exhaust or starter. Every bracket and pulley was on.(no fan) Have a steel balancer on and the distributor was even on. It came in at 712 or 715. It was 71 something can't remember exactly. And that's with no AC pump or bracket.
Old Jul 19, 2012 | 07:55 AM
Run to Rund's Avatar
An aluminum part of the same size and thickness as an iron part will weigh about 1/3 as much. Iron heads weigh 47 lb more or less, and BBO intakes about 56 lb. SBO intakes are probably about 45 lb. I guess. That difference is about the Olds advertised difference between SBO and BBO engines.
Old Jul 20, 2012 | 06:18 PM
So if you had an aluminum intake and headers
and aluminum heads you could be close to
the small block weight so that SBO springs wouldn't
be that affected .
Old Jul 21, 2012 | 06:54 AM
be that affected .
That seems to be the general consensus! If you still want it higher, you can always do the springs later.
Old Jul 25, 2012 | 08:17 AM
Not even close. I have personally weighed a bare 455 block using the finest Chinesium bathroom scale that WalMart sells, and it came in right at 200 lbs. FYI, a WMW 403 block clocked 170 lbs on the same scale.
Old Jul 26, 2012 | 04:35 AM
Mr. Johnson
I Was told a bare block weighed 400. We used an old chain scale older then the car itself. the complete full motor came in at 710. It weighed myself and it was accurate but I only weigh 130. So I can see if the accuracy diminished adding more weight. Bit I thought it was pretty accurate.
Old Jul 26, 2012 | 06:51 AM
Was that the bathroom scale the wife uses?? LOL!
Old Jul 26, 2012 | 07:09 AM
Sounds about right to me.
I can lift a bare block on an engine stand halfway off the ground (2 wheels on the ground, 2 wheels off) to "hop" it up or down a step-off without a problem, and I'm no Hulk, so that lift being = to a bit over 100# (including engine stand portion) sounds accurate.
I can also "roll" a bare block around on the floor without much strain - if it were 400#, then no way, dude.
Old Jul 26, 2012 | 02:21 PM
ah64pilot's Avatar
If a bare block weighs 400 lbs then I must be superman. I can lift a bare, BARE! block by myself and put it in the bed of a truck. I would imagine that Joe's scale was close...200 lbs sounds and feels about right. When you add the crank, rods, pistons, cam, heads, and intake...I would think you'll be in the area of 500-600 lbs.
If you take the difference of aluminum heads and intake into account you can imagine that the weight savings are quite substantial. I can carry one cast iron "E" head with both hands. Conversely, I can carry both aluminum heads (one in each hand) by the center exhaust ports.
I think a 455 with a completely aluminum top end is still substantially lighter than a 350 with all cast iron components.
Old Jul 26, 2012 | 04:42 PM
So we've taken 10 days to determine that a 455 with an aluminum top end is about the same weight as a 350, interesting.
Old Jul 26, 2012 | 11:20 PM
ah64pilot's Avatar
You know...I have one of each sitting on the garage floor...I guess I could weigh each of them and then get the weight of the aluminum heads and intake to compare, but why would I wanna end this conversation with an absolute answer? I like that nobody knows for sure lol!
But, I would make it 11 days and say that a 455 w/ aluminum top end weighs LESS than a stock 350.
Old Jul 27, 2012 | 06:31 AM
380 Racer's Avatar
I would have to say that I really don't care........LOL.
Old Jul 27, 2012 | 07:49 AM
What's really interesting is we've talked about this for 11 days, thanks to an unamed source, and not even an argument! Go figure!
Old Jul 29, 2012 | 07:30 AM
Shradezz70S's Avatar
I am putting coil overs in mine. I don't have a clue as to what any of the the parts I am changing are going to do to the ride height. It's just money right? Just don't tell the wife.
falconsfan
May 14, 2015 05:47 AM
oldrelics
Non-Olds Engines
Jun 12, 2014 07:09 PM
mcutlass1969
Jun 11, 2009 06:27 AM
shaks 442 clone
Jul 29, 2007 09:27 PM
Charger1973
Dec 3, 2006 08:43 PM
