1976 455 upgrades
Old Oct 13, 2016 | 04:35 AM
deadeyejedi's Avatar
1976 455 upgrades
im going to start this thread on the upgrading process of my 1976 cutlass supreme 455 ,ill be working on it this winter .as it stands now everything is bone stock and im looking to wake it up .dropped my 1970 e heads off at the machine shop and got
quoted between 8 and 9 hundred to redo them. includes new valves, guides,seals ,springs and machine work .were going with the 2.072 and1.625 valves they currently have the 2.000 valves.id liked to use my original rockers , retainers and push rods .which brings me to my first question how much can we mill off the heads and still use my original push rods?
Old Oct 13, 2016 | 04:57 PM
cutlassefi's Avatar
Depending on the valve job and head gasket you use probably only about .020 or so.
Old Oct 17, 2016 | 09:47 AM
Got the eheads back from the machine shop . Installed stainless steel valves 2.075 on the intake 1.710 on the exhaust new guides and dual valve springs from comp cams 125lb on the seat and 245lb open . New retainers,locks and seals milled .008 off the heads to get them smooth and took a little off the exhaust as well . Cost came in at $1000 a bit over the estimate. Time to make a decision on the cam .
Old Oct 17, 2016 | 10:04 AM
Wow, new push rods are cheap so I would have just figured out what length was needed after all the machine work and ordered new ones. You still need to verify correct lifter preload.
Old Oct 17, 2016 | 10:15 AM
I may end up buying the push rods as well .have no idea about how to verify correct lifter preload I'll leave that up to my engine builder buddy in the process of ordering a e Brock 2151 intake and a 800 cfm ebrock carb .
Old Oct 17, 2016 | 10:41 AM
cutlassefi's Avatar
Ditch the Edelbrock carb, it'll never work like you want it to.
Why so big on the exhaust valves? You have low compression correct?
Old Oct 17, 2016 | 10:57 AM
Yes low compression but machine shop guy said he went a little bigger on the exhaust due to the condition of the heads around the ports . Does that make sense and do you see any issues with that?
Old Oct 17, 2016 | 11:06 AM
texxas's Avatar
X2 plus it will hurt gas mileage, not like that's a concern with a 455. If you are starting from "bone stock" get a 73-74 double hump transmission cross member so you can put a proper dual exhaust on the car. It will make a huge difference.
Old Oct 17, 2016 | 11:12 AM
Yes been searching for double hump for a while now .do have a quadrajet from a 1973 350 rocket I could rebuild .or use the existing stock quadrajet that's on it.ill hold off on carb selection for now
Old Oct 17, 2016 | 01:40 PM
cutlassefi's Avatar
He should've just put seats in it.
I made 415hp and 540tq on a 442 W30 build. It had the original intake, carb and H heads on it with 1.62 exhausts. That's one reason why it made so much tq.
I'd do a single pattern cam even more so now.
Old Oct 17, 2016 | 02:06 PM
He did say they had to pound the valves out because they were rusted in I'll take your suggestion on a cam I doubt this motor would ever make 400 horse with these pistons but we'll see I might end up with a three thousand dollar boat anchor
Old Oct 17, 2016 | 02:32 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Use the Qjet off the 455, it will be closer and is 800 cfm, the 73 is a 750 cfm.
Old Oct 18, 2016 | 12:32 PM
If I stick with my quadra jet the edelbrock2151 has no provision for my choke stove what's the alternative choke system for the q jet?
Old Oct 18, 2016 | 12:55 PM
Electric. Just remove the three screws holding the thermostatic coil on, remove the gasket, attach the electric choke coil, and connect it to an igniton switched 12 Volt source. I put a tubing cap on the threaded hot air nipple just to keep dirt out.
I bought the one on my car from a salvage yard for $5.
Old Oct 18, 2016 | 01:12 PM
Thanks I didn't know there was one I'll look into it.
Old Oct 18, 2016 | 01:49 PM
1970 E-heads
Old Oct 18, 2016 | 11:54 PM
botmbulb's Avatar
How fast do you want to go?
Old Oct 19, 2016 | 03:31 AM
didnt have any numbers in mind .just want a good tire burner, and if i keep the 2.56 gears top end should be plenty scary for me
Old Oct 19, 2016 | 04:35 AM
svnt442's Avatar
I had a 1970 Cutlass S that I put a 455 in and I had 2.56 gears. The suspension was questionable at best so really high speed runs were out of the question, but that thing would scoot with no issues for sure. I also was able to coax a 13.89@97 out of it with those gears in it.
Old Oct 19, 2016 | 06:17 AM
botmbulb's Avatar
That's easy to do with what you have. All you need is a cam and headers. I love running the low compression 455's. I ran one in my daily driver with headers, an Edelbrock Performer RPM cam, stock G heads, stock intake and Quadrajet, stock trans and converter, 3.23 gears, 3900+ lbs., and ran a best of 12.84 @ 100 mph with open headers. Had the same combination in my racecar, except E heads, 3.90 gear, and 3550 lbs., and ran a best of 12.18 @ 109. One more thing that the low compression likes is a lot of timing. I run around 20-22 initial and 45 total. They love it.
Old Oct 19, 2016 | 06:36 AM
X2 on a lot of timing. Run at least 38 total for timing. For part throttle, as much as it can take, usually around 60 degrees. It will help mileage and feel crisper at all throttle openings. The stock cam isn't terrible on the 455, basically the 307 HO or 350 manual trans cam. Talk to Mark about the cam. The Electric choke coil is a replacement for a Chevy Qjet from the late 70's and on. I use a dab of JB weld inside the housing to block the vacuum port.
Old Oct 19, 2016 | 07:17 AM
thanks guys good to know I'll make a note of it .
Old Oct 19, 2016 | 08:59 AM
Yeah, but doing that you're kinda screwed if you (or another person) want to go back to the hot air choke with that carb. A tubing cap on the port makes it easy to swap back, plus it keeps critters out of the choke housing.
Old Oct 19, 2016 | 01:56 PM
RetroRanger's Avatar
72 Olds CS
I used silicone on that hole and a rubber cap on the port.
Old Jan 4, 2017 | 11:37 AM
Found a nice duel hump crossmember for the car got it sanded primed and painted will put that in soon. pm sent to mark on cam and lifters .looking at headers now as well .
Old Jan 9, 2017 | 02:03 PM
442fanatic's Avatar
Jeff,
I went with Thorton MFG on HO cast exhaust manifolds. They acquired the specs and dies and reproduce the higher flowing dual exhaust manifolds from the w30s.
I had hedman headers on my 350 prior to the swap to the 455. I didn't care for them, hung too low, until you got headers tightened up after multiple heat cycle they would stop leaking, that was also using a copper crush style exhaust gasket as well.
I also recommend going with the quadrajet. I live in the midwest and prefer the hot air choke, more responsive for me in killing the choke than the electric. I did the electrico on the olds 350 with edlebrock Performer RPM intake and 650 Ebrock carb. Still have it on the motor, on the stand should I find something to put it in..
Old Jan 9, 2017 | 03:31 PM
I did consider the thortons on my 72 350 it would make install much easier. Wish there were some comparisons in horsepower between them and headers .
Old Jan 9, 2017 | 05:36 PM
cutlassefi's Avatar
30hp/tq is a real good number. But it also depends on the mods done.
Old Jan 10, 2017 | 04:00 AM
thanks, thats a pretty respecful number .worth going the extra work .when your stating out around 200 hp every little bit counts .
Old Jan 21, 2017 | 04:24 AM
worked on removing the single hump crossmember last night and taking out the exhaust system.can you believe this great big 455 breathing out a single 1-7/8 tailpipe !trying to keep everything in tack in case someone needs a complete system .even has the old test pipe in place of the cat on it .
Old Feb 3, 2017 | 11:54 AM
  #31
Kennybill's Avatar
I'd at least get a 3:08 rearend. That would really wake it up.
Old Feb 25, 2017 | 02:29 PM
  #32
finally getting around to taking the motor apart. spent 3 hours taking off the exhaust manifolds.(amazing how tough those bolts are)everything is coming off pretty well .ended up buying the w/z manifolds from fusick olds and a edelbrock intake .engine looked great inside 'the original owner must have done regular maintenance .
Old Feb 26, 2017 | 12:43 PM
  #33
Cue the snowball effect !! After looking at some of the brittle gaskets as I take this motor apart I decided to pull it out and replace the rear main seal and oil pan gasket . I'll have the opportunity to clean , paint and regasket .may have to wait for a little nicer weather .the time I spent taking things apart the hard way I could have had it out on a stand .it appears to have had the timing chain and gears replaced, not sure if these 76 455's had those gears covered with that plastic like material that use to shatter all to hell.already have a cloyes double roller for it .
Old Feb 26, 2017 | 05:50 PM
  #34
Kennybill's Avatar
MAW, (might as well) while it's out, you might as well freshen the short block. New cam & lifters, yada yada. Put the Ford 460 rubber 2 piece rear main seal.
Old Feb 26, 2017 | 05:53 PM
  #35
I hear ya ! Been reading about the ford seal sounds like a good canidate
Old Mar 4, 2017 | 03:26 AM
  #36
update ! so the motor is out (big red engine hoist from tractor supply doesnt have a long enough boom for this long nosed cutlass but we got around it .my son and i got it on a stand and removed the heads pushrods and lifters spent a couple hours wire brushing and gasket scraping .finally got the block painted by ten oclock last night .expecting my brother in law today so we can install a new rear main seal, cam,lifters and new intake manifold .
Old Mar 5, 2017 | 02:24 AM
  #37
got most of the work done yesterday will bolt on the exhaustt manifolds today and need to get some plugs for the intake .this edelbrock 2151 came with cast iron blanks to block off the crossovers ,took some grinding but they fit nicely .
Old Mar 5, 2017 | 06:10 AM
  #38
Looks great, its great to open one up and see no gunk.
Old Mar 6, 2017 | 03:47 AM
  #39
thanks eric. we got it back where it belongs yesterday time to get everything hooked up maybe break in the cam this week .
Old Mar 6, 2017 | 06:28 AM
  #40
My hoist, is the same, bloody fun, swinging and shoving to get it on the mounts. Looks good.
