1971 455 in a 1969 442
Old Oct 15, 2017 | 05:45 PM
Franswa's Avatar
Do any early 455s require valve adjustments?
Old Oct 15, 2017 | 06:20 PM
svnt442's Avatar
No.
Old Oct 15, 2017 | 06:43 PM
RROLDSX's Avatar
No but you may have an issue with pushrod lengths if your heads have been planed or your head gasket thickness has changed. Why do you feel your valves need adjusting?
Old Oct 16, 2017 | 08:35 AM
No Oldsmobile engine since the 1957-58 J2 came with adjustable rockers. If your 455 has a stock valvetrain, there is no ability to adjust.
Old Oct 16, 2017 | 11:27 AM
Franswa's Avatar
well I have a knock that sounds like in a head not in block...not a hydraulic sound like a rod or piston...what are some preliminary checks I can make if any once I remove valve cover..btw drivers side
Old Oct 16, 2017 | 01:11 PM
The only thing I can suggest is remove the valve covers and inspect the rockers, bridges, and springs. Make sure there is preload on all the valves when they are closed. Any loose rockers at that point need to be checked for wear. If you don't see any substantial wear then you need to pull the intake and inspect the bottoms of the lifters and cam lobes.
How is your oil pressure when warmed up?
Old Oct 17, 2017 | 08:35 AM
Franswa's Avatar
30-35 psi warm...if in fact it’s coming from below what would I look at?..will removing the oil pan reveal anything and I did pull plug wires one at a time with it running but noise remained
Old Oct 17, 2017 | 08:49 AM
You said you think its coming from up top, look at the valve train first. Top end noises sound like tapping, bottom sounds like a heavy knock.
Old Oct 18, 2017 | 04:08 PM
Franswa's Avatar
sounds like a soft thump that’s, “thump, thump,thump with rotation”
Old Oct 18, 2017 | 04:10 PM
Franswa's Avatar
btw anybody..is there a more reliable manual with more detailed info than a chiltons repair manual?
Old Oct 18, 2017 | 04:19 PM
Sugar Bear's Avatar
Check that the torque converter bolts are tight.
Old Oct 31, 2017 | 09:01 AM
Franswa's Avatar
Thum
update: eliminated top end possibles and now on bottom...removed pan but no metal flakes or pieces just dirty oil after a change but previous owner said it sat for 7 yrs......nothing hanging down or obvious..so should I be checking mains next and if so what am I looking for or trying to determine?
71cutlassdroptop
Sep 18, 2017 06:09 PM
BeenThere
Apr 20, 2016 09:19 AM
BeenThere
Oct 17, 2015 12:23 PM
bundy
Jan 29, 2014 04:59 PM
Boilerz25
Cars Wanted
Jan 9, 2014 07:43 AM
