1970 delta 88
1970 delta 88
I've got a 1970 delta 88 455 2bbl and I can not for the life of me, find a vacume diagram for it. Any help at all would be great.
Yeah, that's a smart@$$ answer. It's also not wrong. There isn't a lot of rocket science in vacuum connections on a car this age. Distributor vacuum advance goes to the ported vacuum connection. EVERYTHING else (AT modulator, power brakes, source for HVAC control, vacuum trunk release, etc) goes to manifold vacuum. Any port in an intake runner is manifold vacuum. There is no practical difference in any of them. Your car came with Transmission Controlled Spark, which is a prehistoric emissions control system that disables vacuum advance in lower gears. That solenoid valve splices into the hose from the distributor to the carb. Most people by pass it.
This is your lucky day. With your charming attitude and command of the English language, especially spelling, I know a couple of internet forums where you would be a perfect fit.
You just "called out" the most valuable resource on this forum. Go get your free advice elsewhere and don't let the doorknob hit you in the butt on your way out.
ddd777
August 5th, 2015 05:12 PM
