1969 455 rear main seal install question
Old Nov 21, 2017 | 10:43 AM
1968Cutlass_S's Avatar
I am going to be replacing my rear main seal on my 1968 Cutlass S. The motor is a '69 455 out of Toronado. Do I need to remove the transmission to do this. I know on a Chevy you do but from what I have seen on a Olds 455 in the chassis manual and on videos it's just the rear main cap? Any help would be very appreciated.
Old Nov 21, 2017 | 06:24 PM
Sugar Bear's Avatar
No need to remove transmission.
Old Nov 21, 2017 | 06:55 PM
Man, that is music to my ears. I am replacing the oil pan already so this keeps things simple.
Old Nov 21, 2017 | 11:55 PM
Get rid of the rope seal and replace it with a neoprene seal. I can't remember the part number, it's original application is a Ford 429 engine. You may have to loosen the other main bearing caps to let the crank drop a little to slip it into place. The ford part is much easier to install
Old Nov 22, 2017 | 12:06 AM
Gerald Nickels's Avatar
Ford 460 rear main seal
Old Nov 22, 2017 | 07:31 PM
Macadoo's Avatar
If you decide to use the ford seal, watch the first part of this video first.
Old Nov 22, 2017 | 07:56 PM
cutlassefi's Avatar
If you use a Viton seal trimming the back is not necessary.
Old Nov 23, 2017 | 10:23 AM
Macadoo's Avatar
Now you tell me
Old Sep 30, 2019 | 04:04 PM
VinMichael's Avatar
I trimmed the back on the rubber seal. I installed it without the crank to check for crush. There is no crush. It will move back and forth very slightly. Is this normal?
atkinsom
Feb 28, 2019 06:16 AM
paul879
Jun 26, 2014 04:47 AM
W70442
Jul 22, 2011 06:55 AM
toneypenna
Oct 7, 2010 05:19 PM
1969cutlazz
Apr 13, 2010 10:35 PM
