1969 400g motors
Old Jun 10, 2025 | 04:23 AM
442b's Avatar
1969 400g motors
Did the 1969 Olds 400G motors suffer from poor oil flow? I've read where the oil passages should be opened up some by drilling them out making for better oil flow. I figured while the motor is apart, that should be done. Thoughts?
Old Jun 10, 2025 | 08:53 AM
67OAI's Avatar
Old(s)GuysRule
The "G" block has the same oil passages as its brother, the 455 block. A street or street/strip performance motor will not need to have the oil passages enlarged. Restricted pushrods can be used if you will have full rollerized rocker arms. This may keep a slight amount more oil being delivered to the main bearings. When rebuilding the motor, I would recommend a high volume oil pump with appropriate pick-up and a larger sump oil pan with a good baffle. Main and rod bearing clearances on the "loose" side and adequate rod side clearance to allow the oil to flow.
Old Jun 10, 2025 | 09:25 AM
stan 65 cutlass's Avatar
what about cross drilling and chamfering the crankshaft, thats an old Mondello trick
Old Jun 10, 2025 | 04:28 PM
cutlassefi's Avatar
Don’t cross drill it. All the crank manufacturers quit doing that years ago.
Old Jun 11, 2025 | 05:49 AM
Interesting, thanks
Old Jun 11, 2025 | 03:13 PM
good advice.
solly
May 22, 2025 05:56 AM
1970442Jack
Jan 22, 2025 05:11 AM
Topaz442
Mar 5, 2023 04:27 PM
Monkeyman0398
Mar 18, 2022 08:41 AM
wantacutlass
Apr 1, 2010 06:26 PM
