1967 Toronado Cam
Old Jul 23, 2009 | 11:43 PM
Threejdsolds's Avatar
1967 Toronado Cam
I have a 1967 Toronado 425 which , upon cleaning and measuring , is very clean.Don't know anything about nickel content but the machinist said the block had almost "no wear". Crank and pistons are good. Had to explain the .921 lifter issue to the machinist . SO, here's the question : is a 39 degree 425 Toro .921 lifter cam interchangeable with a 39 degree 455 cam? I have available a 455 W-30 cam and cannot find in any of the threads if it will work in the 425. Thanks for the help. John
Old Jul 24, 2009 | 10:05 AM
Oldsmaniac's Avatar
Yes, any 39 degree cam will work in a 425 toro block.
Old Jul 26, 2009 | 03:53 PM
Oldsmaniac, thanks for your reply. Was reading the Tech article on valve geometry - math was not my best subject . My buddy and I were comparing engines last night . He is rebuilding a 455 and I the 425. The pushrod lengths are different. Why ,if a "C" head will fit a 455 and a 425,are the pushrod lengths different ? Is there a difference in the blocks between a 39 degree 425 and a 39 degree 455 that affects the pushrod length ? Which pushrod (425 or 455) would be used with a 455 cam in the 425? By the way, when I ordered the lifters from Egge , the rep (after putting me on hold for 5 minutes to ask someone else) said I could not use a 455 cam in the 425. Trying to make this "add up".
Old Jul 26, 2009 | 04:01 PM
2blu442's Avatar
John, can you compare the old pushrods in both the 425 and 455? I would have expected them to be the same length too.
Old Jul 26, 2009 | 05:01 PM
Oldsmaniac's Avatar
Yes in general you cannot use a 455 cam in a 1966 425 UNLESS it is a toro engine with the larger lifters. I dont know what to say about the pushrods but if in good condition you may want to use the 425 units. Be sure to check lifter preload...too much is no good for performance and none will create a noisy valvetrain. If the pushrods are too short you wont have any preload. If they are too long you may have too much.
Old Jul 26, 2009 | 07:34 PM
gmrocket's Avatar
Membership Revoked by Admin
pushrod lengths are different because of a few things,,the .921 lifter is taller at the pushrod cup, some 425's had different height valve stem tips, the rocker bridges are also a little different in height. if your using all factory stuff just make sure your not overcompressing the lifter plunger, or not preloading enough. i like to see 1/2 to 3/4 turn on the bridge bolt. cams can be interchanged
Old Jul 27, 2009 | 05:15 AM
Oldsmaniac's Avatar
Just to be clear , the stock valvetrain is not adjustable by the bridge bolt. Rockers are bolted down tight.
Old Aug 13, 2009 | 07:22 PM
gmrocket's Avatar
maybe i should have said 1/2 to 3/4(compressing the plunger) turn,when on the base circle, before the bridge contacts the head. clear enough?
Old Aug 14, 2009 | 07:44 AM
Note that the larger lifter diameter will make the cam act slightly "bigger", since the valves will open slightly earlier and will close slightly later. The difference will only be a few degrees.
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
waterzap
Jul 29, 2013 11:10 AM
MX442
Mar 24, 2012 03:02 PM
