1958 Olds 371 Power Steering pump Leak and shaft seal replacement
Hello,
My power steering pump on my 1958 Olds 371 is leaking onto the top of lower mounting bracket behind the pulley. I felt all around the reservoir and could not feel any fluid so I can only assume it is coming out of the pump shaft.
I see timken and national make a replacement shaft seal for it. Fusick is suggesting a pump rebuild the Pump seems to run fine just leaks.
Has anyone ever replaced the shaft seal on this pump. If so how difficult? Thanks
http://www.fusickautomotiveproducts....sp?number=7475
EB
EB
fast67vellen2o
Jul 24, 2018 08:15 PM
fast67vellen2o
Mar 2, 2012 05:28 PM
