12 volts for a MSD
Old Jun 16, 2009 | 07:59 PM
442_Mustang's Avatar
12 volts for a MSD
I have a MSD Digital 6 for my 72 Cutlass. Where do I get the wire for the 12 volts for the ignition? I believe the wire that goes to the coil is a resistor wire and would only feed approx. 9 volts to the coil so I don't think that's going to be the source.Anyone else use one of these?
Old Jun 17, 2009 | 02:04 PM
citcapp's Avatar
Replace the resistor wire with a 12 guage wire or run a new 12 guage wire from the run side of your ignition switch use a test light to determine which source to use
Old Jun 17, 2009 | 07:27 PM
Red face
Thank you sir. I didn't want to cheap out and run the ignition from the fusebox.
f-85
Aug 9, 2013 09:22 AM
63super88
Apr 10, 2013 06:05 PM
HouTXCutlass
Aug 16, 2010 11:06 AM
1964F85
Apr 2, 2010 06:50 AM
