1" push-in breather?
Old May 8, 2012 | 07:08 AM
zodiacblueS's Avatar
Does anyone have a source for a push-in breather that will fit the D-shaped grommet on my '73 BB? There are hundreds of 1-1/4" I can find, but no luck with a 1" push-in unit. I deleted the emissions stuff but so far all I have is the old breather that fed back to the air cleaner, which I replaced with a simpler unit. Thanks in advance.
Old May 8, 2012 | 07:30 AM
frankr442's Avatar
Why not just use the factory breather. You don't NEED to use the tubes that went to the air cleaner. Looks great under the hood by the way.
Old May 8, 2012 | 07:40 AM
droptopron's Avatar
delete
If you can't find one locally I have an extra one $5 plus shipping from 11762.
Old May 8, 2012 | 07:56 AM
Thanks, I have the factory unit, but I am looking for something more finished looking, either chrome, or alum, or paint. I've seen them that resemble small air cleaners, with open sides and paper or washable filters. I just can't find one that will push in a 1" rubber grommet hole ?!?!
Old May 8, 2012 | 07:59 AM
droptopron's Avatar
delete
Sorry. the one I have is a chrome push in vented out the bottom. Typical of what you normally see.
JMO but I wouldn't run the stock one either.
Old May 8, 2012 | 08:17 AM
If I can't find the air cleaner style, the one you have sounds like it would work, but it has to have the 1" male push-in at the bottom, like the old factory unit pictured. (the factory unit is as much a fitting as a breather, and doesn't look quite complete.) If it does can I let you know by the end of the day? I am in Colorado, zip 80524. Thanks again.
Old May 8, 2012 | 09:46 AM
droptopron's Avatar
delete
The one I have I ran on stock valve covers so I assume it will work on yours. I think I have an extra D-grommet if yours is old.
Old May 8, 2012 | 12:06 PM
PM sent... I can't get that picture to blow up?
Old May 8, 2012 | 06:06 PM
TripDeuces's Avatar
http://www.knfilters.com/vent.htm
K&N makes some
Old May 8, 2012 | 06:24 PM
ah64pilot's Avatar
Originally Posted by TripDeuces
X2, go to any parts store and pick up a K&N breather. They're about $20 and look nice...I'm actually kinda shocked you didn't find one prior to this post. Check out Summit Racing as well.
Old May 8, 2012 | 06:50 PM
Thanks for your help gentlemen. Ordered one tonight and it will be in place soon.
(btw. I grew up in Houston. I have however, managed to adjust to Colorado.)
Old May 8, 2012 | 07:18 PM
ah64pilot's Avatar
Good deal, glad we could help. I visited Colorado in 2010...I have yet to readjust to Houston
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
Kennybill
Ninety-Eight
Jan 28, 2009 03:51 AM
Swed Olds
Nov 18, 2007 04:51 PM
Ryhelio
Jul 7, 2007 11:49 AM
