Starting Problem
Old Aug 31, 2014 | 10:23 PM
Cane87's Avatar
Starting Problem
Hello all,
My 2001 Aurora doesn't like to start when the engine is cold. After I get it cranked and turned over, it will want to die again 2-3 times. After that, it runs fine and restarts fine. Until the engine get cold again.
I have an employee who will replace the starter for free. My question is, is it actually the starter, or will I be wasting money on an unneeded part?
Thanks in advance.
Old Sep 1, 2014 | 05:18 AM
1970cs's Avatar
Lansing built
I guess my first question would be 3.5 or 4.0 engine? Second would be, does it crank but will not start or no crank? Third how many miles?
Pat
Old Sep 4, 2014 | 11:06 PM
Cane87's Avatar
Pat
1. 3.5.
2. Cranks but will not start. Or, starts but then shuts off. Usually stays on after the fourth restart. The problem only occurs when it's cold. When it's warm, it starts and runs like new.
3. 152K.
Old Sep 5, 2014 | 09:29 AM
Jetstarjim's Avatar
I wouldn't lean to much towards the starter. If you have a "service engine soon" light on, it will help point you in the right direction. If I were to guess, I would consider weak fuel pressure, or consider the failure of an engine management sensor. I had one with a faulty coolant sensor that would "trick" the computer into thinking ( I know, they don't really think, lol!) the engine was at operating temp, and didn't like to run cold.
Old Sep 5, 2014 | 05:10 PM
1970cs's Avatar
Lansing built
I would guess that Jim's idea is what I was thinking also! Fuel pressure regulator is what my guess but you need to measure the fuel pressure with a gauge to determine if that is it.
Pat
bccsrc
Nov 29, 2011 11:08 PM
The Stickman
Oct 25, 2009 07:04 PM
Maverick
Jun 4, 2008 07:46 AM
bjtstarfire
Oct 29, 2007 06:51 PM
Classic Cutlass
Feb 15, 2007 04:54 AM
