mass air flow sensor
Old Dec 6, 2008 | 06:16 PM
schapman33
Guest
Posts: n/a
mass air flow sensor problem
have 01 aurora. the check engine lt came on , went to the dealer who said mass air flow sensor was bad. the mechanic cleaned it , said it might work and reset the light. Check engine light is back on. can i put an after market sensor on and how would i reset the check engine light.
Old Dec 8, 2008 | 05:23 AM
Oldsguy's Avatar
Past Administrator
Can't you get an OEM type replacement sensor at the auto parts store? Anyway, if redog doesn't see this post give him a shout via PM, he has some experience with the newer models, so does Olds64.
Old Dec 8, 2008 | 06:04 AM
Go to the auto parts store and have them pull your codes. They will do a print out giving you the codes and what they mean. Use that to trouble shoot your problem. If it is the mass air flow sensor then you will probably have to get an OEM replacement from the dealership or the auto parts store. Be prepared to spend some $$$. Mass air flow sensors are pretty complicated devices.
Old Dec 8, 2008 | 07:49 AM
MAF is $80 for a reman or $165 for brand new from Partsamerica.com. Since your car is OBD II, the only way to reset the light is to use a scan tool.
Lee_A
Aug 15, 2013 12:32 PM
chip-powell
Jul 7, 2013 01:31 PM
AZ442
Jul 16, 2010 05:34 AM
redvettemike
Dec 11, 2009 07:06 PM
cormike
Aurora
Jan 4, 2009 07:30 AM
