Aurora 3.5 Front End
Old Jan 6, 2010 | 10:09 PM
RDSHARE's Avatar
I'm Back again. Seems every 6 months or so something else breaks down...
My 01 Aurora 3.5 has 76000 miles on it. I have already replaced a leaking rack and pinion at 65K and a front axel about a yr ago.
New Years Day was about 24 degrees. Took the car out, no problem until I went to parallel park, could not turn the wheel from a dead stop. When I got home, I checked the power steering reservour and it was empty. Filled it with power steering fluid and 5 days later, the wheel again is very difficult to turn. NO leaks on the garage floor. I have not checked the level again, although I will later today.
Is it worth replacing the power steering unit? Or just call it quits with the car and move on. The rest of the car is in VG condition, no scratches, no hits, good tires, I just don't know if now the nickel and diming starts.
I had a 94 Olds LSS that I ran for over 229K miles until the A/C unit went, and that repair was more than the car was worth. SO, do I cut my loss now, or keep it? Has anyone else had front end trouble? Seems that steering has been an issue with this model.
Old Jan 7, 2010 | 05:44 AM
Have you priced a power steering pump at your local auto parts store? If your rack and pinion is malfunctioning again then hopefully you have a warranty on the part so you can get a new one for free. If you are good with tools it shouldn't be too hard to replace a power steering pump. Surely it wouldn't take more than a weekend to do it.
Old Jan 7, 2010 | 06:51 AM
70 cutlass s's Avatar
The power steering pump is 120 dollars and if it ends up being the line the pressure one is 65 dollars. This is the price from auto zone.
Old Jan 10, 2010 | 10:11 AM
RDSHARE's Avatar
The Aurora is going back into the shop. Power Steeing unit and they will replace the high pressure hose. $200 is much less than a new car.. and the question what to buy
oldsrocket88
May 15, 2015 08:21 PM
DeucePhaeton
Jul 21, 2014 06:22 PM
1970VistaCruiser
Oct 2, 2012 07:55 PM
CHRISD
Aug 29, 2006 01:23 PM
HighHopingAurora
Aurora
May 15, 2006 02:33 PM
