'01 Aurora keyless programming
The one I did was an '03 Poncho and a '01 Tahoe, so I'm not sure if this will work but I found this to try...
Instructions
Read more: How to Program the Keyless Entry For a 2001 Oldsmobile Aurora | eHow.com http://www.ehow.com/how_6532534_prog...#ixzz1TRrrrCLq
Are you having trouble with your original or what is the purpose of needing to do this?
Instructions
- 1 Enter your Aurora with your ignition key and keyless remote in hand and close all of the car's doors behind you.
- 2 Insert and remove the key from the ignition.
- 3 Press and hold the "Unlock" tab on the driver's side door and be prepared to hold it pressed through the following step.
- 4 Insert and remove the key from the ignition three times in a row and release the "Unlock" tab after the third time. Wait for the vehicle to emit three beeps, indicating the beginning of the programming sequence.
- 5 Press and hold the "Unlock" and "Lock" buttons on your keyless remote until the system beeps again, indicating that the programming of the remote was successful.
- 6 Repeat step 5 with any additional remotes, and remove the key from the ignition to end the programming sequence.
kandelino
Nov 5, 2010 06:45 AM
