gas millage
Old Feb 17, 2007 | 01:35 PM
myalero's Avatar
Unhappy gas millage
hi guys. I just got a 2000 alero gl with 63000 miles on it. My gas millage is almost half of manufacturer's suggestd gas millage. what are the things to check before I make a dash to dealer.
Old Feb 19, 2007 | 06:21 PM
mitsudave's Avatar
Is the check/service engine light on or blinking?
O2 sensor, clogged air filter, clogged fuel filter, plugs, wires, airflow sensor, timing/cam/crank position sensor, clogged catalytic convertor...could be anything.
Most auto part store chains will read your OBD or OBD2 codes for free, then you can narrow it down!
Old Feb 20, 2007 | 05:37 PM
Redog's Avatar
New Plugs, fuel filter, new air filter, cloged PCV valve, heavy foot?
Also sign up for Aleromod.com, a lot of guys can help you over there too
Old Sep 17, 2007 | 02:33 PM
Tucker442's Avatar
Pull the hose off of the fuel pressure regulator and see if gas comes out of it. If so it needs to be replaced, I've seen a few or these
Old Sep 17, 2007 | 02:41 PM
Ed39's Avatar
start off simple... check the air and fuel filters first.. if it were a plug or wire misfirng and ck engine light would be on. i assume the light is not on right?
J-(Chicago)'s Avatar
Seasoned beater pilot.
02-20-2007, 07:37 PM
Old old old.
chip-powell
Apr 7, 2015 09:19 AM
Pete77
Jul 9, 2006 03:11 PM
JoshF85
Oct 20, 2005 12:40 PM
72RocketPower
Feb 25, 2005 12:41 PM
