2003 Alero Wont Start Unless
Old Sep 16, 2008 | 01:31 PM
liljughead34's Avatar
I have a 2003 Alero that wont start unless you turn the key to the on position for a minute or two turn it off and then start it. We changed the spark plugs,fuel filter, mass air flow, fuel pump pressure is 55psi. Any suggestions?
Old Sep 16, 2008 | 01:38 PM
Is there a check engine light?
Old Sep 16, 2008 | 01:42 PM
nope not at all
Old Sep 16, 2008 | 09:38 PM
Redog's Avatar
Could be the ingition module going bad. Be careful, my car actually shut off on me at 60 MPH
Happened to mine.
See if it can be rekeyed to you're current key.
Cost me $555
Old Oct 26, 2008 | 08:21 PM
The_Jeremiah's Avatar
none of those things you replaced would have anything to do with what your problem is, they are connected to your ignition circuit, but not directly to the starting system. does it turn over but not start? or does it not turn over at all?
Old Oct 26, 2008 | 08:55 PM
Redog's Avatar
Age of battery?
Does the gauges go all the way up and then reset? (0-140 and 0-7000)
Chesrown 67 OAI
Alero
May 2, 2014 07:58 PM
Toyaholic
Jul 21, 2013 12:42 PM
musicars
Alero
Feb 19, 2013 03:10 PM
Aceshigh
Jul 30, 2009 02:48 PM
