68 442 4-core radiator
Old Oct 12, 2014 | 07:59 PM
kansjfr's Avatar
My '68 442 came ordered with a heavy duty radiator, and needs a new one. It's leaking, and I don't see much point in trying to repair a 46-year-old radiator. I checked it the other evening, and it's a 4-core radiator. I want to replace it with the same thing, not an aluminum or plastic one. Most sites I've checked are 2-core aluminum with plastic tanks. Where is the best place (that is cheapest for decent quality) to get a brass, copper core, 4-core radiator? Any comments would be helpful.
Old Oct 12, 2014 | 09:34 PM
70Post's Avatar
Save your original and have a good radiator shop install a new 4 row core in it. It will FIT RIGHT.....which is usually not the case with replacement radiators. If it's your original it'll the cool "Harrison" logo stamped in the fill side tank and will also have the correct more-level filler neck (unlike the typical replacement radiator). Make sure they use the original top and bottom "support" rails from your old core (or get a core with those "top hat" profile rails already installed).
Might as well save the original stuff as much as possible....just have it re-cored.
Old Oct 13, 2014 | 09:38 PM
2blu442's Avatar
I agree with Patton. Also, there are codes stamped into the metal tank that show the application and date. If this is the original radiator it would be nice to keep these details intact.
There's a number of threads discussing this, but here's one with some photos to help key out if you've still got the original radiator or not.
John
https://classicoldsmobile.com/forums...ease-help.html
Old Oct 14, 2014 | 08:00 AM
rcorrigan5's Avatar
Randy C.
That's exactly what I did with my '68 4-core and it worked beautifully!
Randy C.
Old Oct 16, 2014 | 10:27 PM
kansjfr's Avatar
Update: I did some more checking on the internet and found a brass/copper 4-core radiator made by Murray with a lifetime guarantee at O'Reilly's online. I had my local store (is there a town anywhere that doesn't have an O'Reilly's ?) order it in, and I took my old Harrison radiator in and put one on top of the other and the new radiator is almost identical to the Harrison original. The fill cap is just a little lower than the original. It fits in perfectly, just like the original, and of course, I'll save the original for later restoration if needed. The original still had the metal tag on it, too. Thanks for the responses.
Old Oct 16, 2014 | 10:33 PM
kansjfr's Avatar
I forgot to mention that the radiator was only $196.xx, which I thought was a reasonably good deal.
Old Oct 16, 2014 | 10:40 PM
Did the new one have the same number of tubes and the same number of fins-per-inch? Many replacement radiators don't and therefore do not cool as effectively as the originals.
Old Oct 17, 2014 | 09:22 PM
kansjfr's Avatar
Appears to be so, it has 4 cooling tubes inside and 8 double-fins per inch, like the original one. My original one is a heavy duty radiator, and I'm guessing the heavy duty one is a 4-core (or tube) radiator instead of a 3-core. Some people have told me that an aluminum 2-core radiator will cool as well or better than the original brass and copper 4-core one, but I wanted to keep the original look of the factory radiator. Also, something that confused me was that the replacement radiator had two metal bands (like shipping bands) vertically around the radiator, and I didn't know whether to cut them off, or leave them on, and of course, the twits at O'Reilly's were of no help. I left them on, I guess I can always take the off later if I was incorrect.
Old Oct 18, 2014 | 08:25 AM
shepo1's Avatar
what was the part number of the new unit.??
Old Oct 18, 2014 | 04:54 PM
kansjfr's Avatar
433165. It's 219.xx, but I got it for 196.89 because I have a business account there.
Alex72cutty
Apr 21, 2015 10:30 AM
rcktdoc
Jul 14, 2014 12:38 PM
59Olds98
Aug 14, 2013 09:38 AM
L69
May 19, 2013 11:01 AM
RPD1659
May 21, 2008 06:55 PM
