Rust where the front window and dashboard meet
Old Mar 9, 2021 | 04:35 PM
Wsbkmike's Avatar
69 Olds 442 Guy
Rust in front window channel
Hey folks. I own a 69 442 and am no expert in body work. So I'd like to know if removing the front windshield to access the rust on the dashboard channel is something a novice like me can tackle or should I take it to a body shop? Thanks in advance.
Old Mar 9, 2021 | 06:33 PM
Depends. You have to know yourself and your capabilities. Are you generally a handy kind of guy? How's your self-discipline? Do your projects usually get completed or do they languish in the shop or garage after you get bored and move on to other things? How much time do you have available? How hard are you willing to work?
Old Mar 9, 2021 | 09:04 PM
edzolz's Avatar
I would say if you are confident with welding in sheet metal yourself, go for it. If not, take it to a good honest (read honest) body shop that has a good reputation.
Old Mar 9, 2021 | 09:26 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You will need to be very careful removing the windshield so you don't crack it. As mentioned you will need to evaluate your skills at welding, body work and paint.
Old Mar 10, 2021 | 05:58 AM
That is a well known problem with our Cutlass' and Chevelles, etc. The metal there is really thin. Problem is once you get that far in you see you "might as well" (MAW's) fix other things while in there, this can lead to a complete restoration and car will be apart for 10 years! So beware!
Old Mar 10, 2021 | 09:37 AM
I had to repair rust in the same area in my car years ago. Now replacement panels are available.
it took lots of cutting, bending, trimming, and welding to repair it. It turned out well.
Old Mar 18, 2021 | 12:01 PM
Wsbkmike's Avatar
69 Olds 442 Guy
Thanks, guys. After reading your comments, coupled with my own research, it confirmed my thoughts that it will be a lot of work. Unfortunately, I'm not a welder and have little experience in sanding, so I'll have to find a reputable body shop that can tackle this, as I also have some rust bubbling underneath the vinyl top. Ugh.
Old Mar 18, 2021 | 12:51 PM
This is unfortunately all too common with these cars. Doing it right requires significant disassembly of the interior to prevent fire and to access all the rust.
Old Mar 18, 2021 | 05:15 PM
Wsbkmike's Avatar
69 Olds 442 Guy
Yep. Thanks, Joe.
On a side note, my 442 was born with the C50 Cameo White with a black vinyl top as I was lucky to find the build sheet while looking under the back bench seat last month. Do you know if the C50 Cameo White is a regular white color as the color of my car, or is it more of a cream color like I've seen on the Olds paint charts for C50?
Old Mar 18, 2021 | 11:42 PM
Originally Posted by Wsbkmike
Yep. Thanks, Joe.
Cameo White is plain white - that's what was used on the 69 H/Os also.
Old Mar 19, 2021 | 10:29 AM
Wsbkmike's Avatar
69 Olds 442 Guy
Well then that's good news for me. Thanks again.
weasel
Body work
Sep 24, 2012 09:54 AM
Texas Jim
Body work
Nov 7, 2009 06:53 AM
Texas Jim
Ninety-Eight
Oct 22, 2009 01:08 AM
Texas Jim
Ninety-Eight
Oct 21, 2009 06:07 PM
Olds64
49
Jul 17, 2009 10:00 AM
