Nasty Vibration/Shudder @ ~3,200 rpm and above
Old September 21st, 2018, 04:33 PM
Terry Wright's Avatar
Hello All. Looking for a little help troubleshooting my '70 442 with original 455 motor and th400 transmission. I get a nasty vibration/shudder at 3,200 rpm or above. The vibration/shudder begins at ~3,200 RPM and is present at highway speeds (in gear or neutral), low speed in 1st/2nd gear, and at zero mph in neutral. No vibration is present at lower RPM. Thus far I've replaced the drive-shaft and U-Joints, and inspected the damper which appeared to be in good condition. Any ideas regarding the potential cause(s) are greatly appreciated!
Terry Wright is offline
Old September 21st, 2018, 05:11 PM
Rocketbrian's Avatar
If it happens in neutral or park it has nothing to do with wheels, tires or driveshaft. I would look into a missing weight on the flexplate or torque convertor as a first step, especially if it started out of the blue.
Rocketbrian is offline
Old September 21st, 2018, 05:28 PM
ragz442's Avatar
If it does it in neutral with no load it should be pretty easy to pin point. Have someone bring the r's up and look at the harmonic balancer, belts, brackets. If nothing found, unbolt the torque convertor and push it back in trans and see if it still does it.
ragz442 is offline
Old September 23rd, 2018, 02:14 PM
Thanks guys. The harmonic balancer, belts and brackets all look good. Next step is unbolting the torque convertor to see if the vibration is still present.
Old September 23rd, 2018, 04:09 PM
dragline's Avatar
Motor mounts?
dragline is offline
Old September 23rd, 2018, 08:01 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Verify the health of the ignition system...wires plugs points cond etc...
droldsmorland is offline
Old September 24th, 2018, 09:15 AM
72Cutlass S
gs72's Avatar
Oil level way too high? Its Easy to check.
gs72 is offline
Old September 24th, 2018, 05:36 PM
All new within past 24 months ... should be "ok". Thanks for the suggestion!
Old September 24th, 2018, 10:06 PM
Should be, but sometimes new doesn't = good.
Fun71 is offline
Old June 18th, 2019, 11:42 AM
Quick update ... it was the torque converter ... vibration is gone! Thanks for all of the help.
Old June 18th, 2019, 12:11 PM
Thanks for the follow-up!
Old June 18th, 2019, 03:02 PM
Glad you were able to find and correct the issue.
Vintage Chief is online now
Old June 18th, 2019, 06:35 PM
Try reclocking the converter on the flywheel. Sometimes you can tune our vibrations. Definitely easier than a converter swap, and cheaper if it works.
matt69olds is offline
Old June 18th, 2019, 06:37 PM
Old June 19th, 2019, 04:32 AM
I noticed that. I assumed he determined the converter was the issue by unbolting it from the flywheel. If he hasn’t removed the converter yet, try reclocking it.
Old June 19th, 2019, 10:30 AM
I noticed that. I assumed he determined the converter was the issue but unbolting it from the flywheel. If he hasn’t removed the converter yet, try reclocking it.
Ah, gotcha. I assumed it was loose and he just tightened the bolts.
Fletchmo72
September 19th, 2017 10:30 AM
HeavyOlds
August 8th, 2017 04:36 PM
oldspower_68
March 20th, 2012 08:43 PM
lionelbob
May 27th, 2010 08:10 PM
ls442
June 9th, 2009 06:54 AM
Quick Reply: Nasty Vibration/Shudder @ ~3,200 rpm and above
