70 442 conv rear seat foam
Old Jan 22, 2009 | 05:35 PM
FL1970442's Avatar
Need new foam for my rear seat bottom. Most suppliers say it did not come pre-formed in my 70 442 convertible. Are they correct?
Old Feb 1, 2010 | 12:58 PM
Olds luvr's Avatar
Grown Azz Kid
I have ran into the exact same issue. I found a local shop to do the foam and burlap and put on my covers for 175 so that was cheaper than I found the rear foam for the hard tops. Call some local upholstery shops and you should be good.
Old Feb 1, 2010 | 01:08 PM
Lady72nRob71's Avatar
From the factory, foam was preformed. It is not common to find it reproduced and if you do find it, it will be costly and may need to be trimmed anyway.
I think the back seat back was just stuffed with cotton batting (no foam). It can be replaced with foam though.
To replace, I would suggest just get sheet foam and new burlap from a fabrics / upholstery store and cut to fit.
Use your original as a template of how much you need. The medium density is best for the bottoms, soft for the backs.
If your foam is 'okay' but just a bit compressed, reuse it and put a 1" thick layer of new foam on top of it to firm it up and fill out the covers.
Old Feb 1, 2010 | 08:14 PM
OLD SKL 69's Avatar
GM Enthusiast
x2
I had to do that on my 71 Supreme front seat and it worked out great. I paid $25 for the 1" of foam sheet I needed.
Is your original material falling apart?
Old Feb 2, 2010 | 06:14 PM
hamm36's Avatar
I got 2" foam (green) from a fabric supply: "Joann's," and "Hancock". I waited until they had a sell for 40-50% off on the foam. It was about $40 after the sale. One sold it by the lineal foot, the other in a sheet that was plenty for the bottoms of either the back, or front bench. But my padding was about shot/gone. I also, beef up the front bottom bench with 3/4"fabric backed and hog ringed that tight across the springs.
heavydan
May 9, 2014 11:59 AM
ctrain22
Dec 30, 2013 05:26 PM
Bayou Olds
Oct 14, 2011 08:47 PM
joades
Mar 10, 2009 05:53 PM
nelsontj
Mar 4, 2009 03:33 PM
