What would you do?
What would you do?
I have two "W" exhaust manifolds on my '70 W-30. The passenger side exhaust is from a 1966 W-30.
My '70 W-30 is pretty correct. I've got the correct rear, trans, dist, carb, intake, air assembly, master cylinder, rad, glass, heads, factory service block () you get the picture.
However. Two of the 5 previous owners were Olds enthusiasts. These enthusiasts also both owned '66 W-30'. Somewhere along the line, one of them must have inadvertently put one of the '66 manifolds on the '70. Would you try and hunt down a "Z" manifold or just accept this "error" as part of the cars history?
I wouldn't loose sleep about it...just keep your eye out for the Z manifold.
One will come along eventually.
Unless you're planning on selling it or entering an OCA show, I doubt
many will call you on it.
You could always go here if it's making you crazy...you OCD?
http://gawain.membrane.com/~thornton/manifold.html
Checked Thornton out but they don't carry date codes. I'm sorry, was I being **** again?
jag1886
March 17th, 2018 12:12 PM
