What would you do?
Old May 23, 2008 | 06:25 AM
344870M's Avatar
What would you do?
I have two "W" exhaust manifolds on my '70 W-30. The passenger side exhaust is from a 1966 W-30.
My '70 W-30 is pretty correct. I've got the correct rear, trans, dist, carb, intake, air assembly, master cylinder, rad, glass, heads, factory service block () you get the picture.
However. Two of the 5 previous owners were Olds enthusiasts. These enthusiasts also both owned '66 W-30'. Somewhere along the line, one of them must have inadvertently put one of the '66 manifolds on the '70. Would you try and hunt down a "Z" manifold or just accept this "error" as part of the cars history?
Old May 23, 2008 | 06:51 AM
Rallye469's Avatar
I wouldn't loose sleep about it...just keep your eye out for the Z manifold.
One will come along eventually.
Unless you're planning on selling it or entering an OCA show, I doubt
many will call you on it.
You could always go here if it's making you crazy...you OCD?
http://gawain.membrane.com/~thornton/manifold.html
Old May 23, 2008 | 11:22 AM
The 66 "W-30" manifold is the same as used on any other 66 442. It also lacks the internal runners that improve flow on the 69-72 W/Z parts.
Old May 24, 2008 | 07:41 AM
344870M's Avatar
OCD? No, but I have been told that I'm wound a little tight.
Checked Thornton out but they don't carry date codes. I'm sorry, was I being **** again?
jag1886
Mar 17, 2018 12:12 PM
olds59
Feb 19, 2009 04:38 PM
68ragtop
Jan 13, 2009 08:36 PM
scott_442
Jan 4, 2008 02:06 PM
1BAD68"S"
Nov 9, 2006 04:30 AM
