w-30 intake
Old Mar 13, 2010 | 06:37 AM
firefrost gold's Avatar
w-30 intake
Parts place has w-30 intakes yes they are a lot of cash . Has any one seen them up close for quality like port size, core shift , runner size? thanks
Old Mar 13, 2010 | 07:27 AM
stevengerard's Avatar
it is virtually identical to a stock W30 manifold which is identical to an iron manifold except made out of aluminum, doesn't flow any different just 40lbs lighter.
Old Mar 13, 2010 | 10:01 AM
I had read That they flow as you stated the same and iron for factory w-30
yet lighter Im glad to hear the the repo's are good pieces . Have been told by both miller and mondello that a w-30 intake on good heads both ported will ,make in the low 500 range with a good cam you know the drill . Mondello said they like the performer with a cut down base better I thought a w-30 with a small plate to raise the butterflies out of plenum would be better???
Wildcard
Dec 26, 2012 07:48 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
svnt442
Jul 17, 2011 04:43 PM
71cuttyS
Oct 31, 2007 04:58 PM
