torsion bar install
Old December 14th, 2014, 07:20 PM
fn67rocket's Avatar
torsion bar install
anybody have experience in installing a trunk lid torsion bar on a 67 olds 442, it seems you would have to twist the bar pretty far to latch it in place, any ideas would be great, tired of using shower curtain rod to hold trunk lid up
fn67rocket is offline
Old December 14th, 2014, 07:25 PM
Octania's Avatar
special tool?
Beasty vice grips maybe
I usually just REMOVE them for sale, which is easy- Big Fat Pry Bar.
Octania is offline
Old December 14th, 2014, 07:30 PM
Oldsmaniac's Avatar
Have done this, not fun and I struggle thru each time. Small pipe wrench with small extension on handle will let you twist the rod. A helper can assist pulling out on the spring bar to shorten it a bit so you can get the end in where it belongs. I work at the end that has three slots for tension adjustment.
Oldsmaniac is offline
Old December 14th, 2014, 07:45 PM
Run to Rund's Avatar
Olds had a special tool that is easily duplicated, makes the job easy. Notch the end of a piece of pipe so it fits over the torsion bar; drill across the side and put a carriage bolt through the hole to hook onto the bent end of the torsion bar.
Run to Rund is offline
Old December 14th, 2014, 08:25 PM
fn67rocket's Avatar
great idea, I will try that, thanks all for the responses
Old December 15th, 2014, 01:02 AM
kansjfr's Avatar
Brilliant!!!!!!!!!!!
kansjfr is offline
Old December 15th, 2014, 04:42 AM
Where was this when I needed it 4 years ago?
Allan R is offline
Old December 15th, 2014, 06:27 AM
Oldsmaniac's Avatar
Like!
bluecab
January 30th, 2012 08:36 PM
Mark71
May 5th, 2011 10:24 AM
musicars
Bravada
October 23rd, 2010 02:48 PM
Matt15
August 26th, 2010 01:10 AM
Papa Bear
May 10th, 2010 06:49 AM
Quick Reply: torsion bar install
