torsion bar install
Old Dec 14, 2014 | 07:20 PM
fn67rocket's Avatar
torsion bar install
anybody have experience in installing a trunk lid torsion bar on a 67 olds 442, it seems you would have to twist the bar pretty far to latch it in place, any ideas would be great, tired of using shower curtain rod to hold trunk lid up
Old Dec 14, 2014 | 07:25 PM
Octania's Avatar
special tool?
Beasty vice grips maybe
I usually just REMOVE them for sale, which is easy- Big Fat Pry Bar.
Old Dec 14, 2014 | 07:30 PM
Oldsmaniac's Avatar
Have done this, not fun and I struggle thru each time. Small pipe wrench with small extension on handle will let you twist the rod. A helper can assist pulling out on the spring bar to shorten it a bit so you can get the end in where it belongs. I work at the end that has three slots for tension adjustment.
Old Dec 14, 2014 | 07:45 PM
Run to Rund's Avatar
Olds had a special tool that is easily duplicated, makes the job easy. Notch the end of a piece of pipe so it fits over the torsion bar; drill across the side and put a carriage bolt through the hole to hook onto the bent end of the torsion bar.
Old Dec 14, 2014 | 08:25 PM
fn67rocket's Avatar
great idea, I will try that, thanks all for the responses
Old Dec 15, 2014 | 01:02 AM
kansjfr's Avatar
Brilliant!!!!!!!!!!!
Old Dec 15, 2014 | 04:42 AM
Where was this when I needed it 4 years ago?
Old Dec 15, 2014 | 06:27 AM
Oldsmaniac's Avatar
Like!
bluecab
Jan 30, 2012 08:36 PM
Mark71
May 5, 2011 10:24 AM
musicars
Bravada
Oct 23, 2010 02:48 PM
Matt15
Aug 26, 2010 01:10 AM
Papa Bear
May 10, 2010 06:49 AM
