Shifter swap??
Old July 26th, 2015 | 05:30 PM
bigblockchris's Avatar
Shifter swap??
I recently bought a consol for my 71 442 it was original without one and had column shift. My question is with his new consol,it was for the basic floor shifter not the hurst dual gate. Im wanting to put a dual gate in this consol will it fit or did they take their own specific consol?
Thanks for any info
Chris
Old July 27th, 2015 | 07:06 AM
Thanks for any info
Chris
There are molded lines on the underside of the console that show you where to cut for the dual gate. Be careful, as there are also lines to cut for the four speed, so be sure you are cutting on the correct lines. Your 1971 Chassis Service Manual has a drawing that shows which ones are which. You will need the correct woodgrain and plastic insert for the top of the console to cover the hole for the original shifter, also.
Old July 27th, 2015 | 05:14 PM
Thanks for the info joe.
Chris
marxjunk
June 12th, 2014 12:34 PM
boese1978
September 28th, 2012 07:09 AM
69CutlassAlex
February 9th, 2012 05:26 AM
Napoleon Solo
February 8th, 2012 10:15 PM
olds4life
February 27th, 2009 08:54 PM
Quick Reply: Shifter swap??
