Shifter swap??
Old Jul 26, 2015 | 05:30 PM
bigblockchris's Avatar
Shifter swap??
I recently bought a consol for my 71 442 it was original without one and had column shift. My question is with his new consol,it was for the basic floor shifter not the hurst dual gate. Im wanting to put a dual gate in this consol will it fit or did they take their own specific consol?
Thanks for any info
Chris
Old Jul 27, 2015 | 07:06 AM
Thanks for any info
Chris
There are molded lines on the underside of the console that show you where to cut for the dual gate. Be careful, as there are also lines to cut for the four speed, so be sure you are cutting on the correct lines. Your 1971 Chassis Service Manual has a drawing that shows which ones are which. You will need the correct woodgrain and plastic insert for the top of the console to cover the hole for the original shifter, also.
Old Jul 27, 2015 | 05:14 PM
Thanks for the info joe.
Chris
marxjunk
Jun 12, 2014 12:34 PM
boese1978
Sep 28, 2012 07:09 AM
69CutlassAlex
Feb 9, 2012 05:26 AM
Napoleon Solo
Feb 8, 2012 10:15 PM
olds4life
Feb 27, 2009 08:54 PM
